peugout 206 hdi
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116098
Printed Date: April 08, 2026 at 1:14 AM
Topic: peugout 206 hdi
Posted By: cms customs
Subject: peugout 206 hdi
Date Posted: September 04, 2009 at 4:48 AM
I need the alarm wiring diagram for the peugout 206 hdi
urgent please
Posted By: howie ll
Date Posted: September 04, 2009 at 7:01 AM
Year please if remote start, otherwise here goes from memory, I can show you some photos if you PM me with your email address. don't ask for colours as they chop and change every three weeks.
12volt+ Constant = Ignition loom
Starter = Ignition loom
Ignition 1 =  Ignition loom
Ignition 2 and ACC = Ignition loom headed for fuse/BSI box under dash.
Ground = bolts securing  vehicle's GREEN/ YELLOW ground (massa) cables.- NOTE one of the ignition leads is also this colour.
Indicators. BSI box, top + at central rectangular plug
Locks = motor wires at left hand rectangular plug, top of BSI box*
Door and hatch contacts, 1 of 2 quadlock plugs at far end, top of BSI box.
Engine bay entry, spare grommet, where main loom goes through to engine bay.
Brake light, at brake light switch.
Parking brake, dissemble rear of centre console, right hand side is cable entry for switch, side that goes to ground when handbrake (parking brake) is pulled up (not GREEN/ YELLOW).
Tach, engine management box forward of right hand wheel arch, engine bay, one the separate leads usually white which you will see if you open up the outer covering. TEST
Hood, separate switch required.
* On earlier versions, pre 2001, you can find neg lock/unlock triggers and door contacts in a thin rectangular plug to the front of BSI box. Sometimes i've failed to pick up the hatch switch in the front, I've had to go back to the hatch light. I've never found 2 wired the same way!
Date Posted: September 04, 2009 at 9:40 AM
ok thanks for your reply,i have fitted a door c/lock motor to drive the c/locking and for the other wires i found them
Posted By: howie ll
Date Posted: September 04, 2009 at 10:55 AM
Fitted a door motor? Waste of time and money if you've already got factory central locking.
