remote window operation
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116260
Printed Date: April 02, 2026 at 8:05 PM
Topic: remote window operation
Posted By: eltazz805
Subject: remote window operation
Date Posted: September 11, 2009 at 1:30 PM
I have seen this on another car and i want to be able to do it with my car and i need help, i dont know how to go about doing it. Here's what i want; I have a 2008 mazdaspeed 3. What i want is for all my windows to go up when i lock my doors with the stock key remote. And i want them all to come down when i unlock the car. I dont know how much about electrical systems i know more about engines so i dont do this often. All i know is that i need relays lol. Can anybody help?
Posted By: howie ll
Date Posted: September 11, 2009 at 1:42 PM
You will need a pair of timer relas, 528t  triggered by the lock/unlock motor wires and a pair of 529ts, per two windows. the 528ts wil be set for say 5 secs each (time your windows up and down, add 2 secs.) to control the closers, you can't use relays on their own, you will burn out the window motors.
Also this is dependant on how the window motors are wired, unless you've two wires going to each window motor forget it.
Posted By: tommy...
Date Posted: September 11, 2009 at 2:09 PM
Power UnlockBLACK/ BLUE(-)BROWN PLUG BEHIND GLOVEBOXposted_image
posted_imagePowerLockBLACK/ BLUE(-)IN BROWN PLUG BEHIND GLOVEBOXposted_image
posted_imageDriver Mtr UnlockYELLOW/BLACK(REV)IN HARNESS TO DRIVER KICKPANEL TO DOOR
posted_imageDriver Mtr LockWHITE/ BLACK(REV)IN HARNESS IN DRIVER KICKPANEL TO DOOR
posted_imageLF Window UpYELLOW/BLACK(AC)MASTER WINDOW CONTROL SWITCH
posted_imageLF Window DnWHITE/ GREEN(AC)MASTER WINDOW CONTROL SWITCH
posted_imageRF Window UpYELLOW/VIOLET(AC)MASTER WINDOW CONTROL SWITCH
posted_imageRF Window DnWHITE/ VIOLET(AC)MASTER WINDOW CONTROL SWITCH
posted_imageLR Window UpBLUE/WHITE(AC)MASTER WINDOW CONTROL SWITCH
posted_imageLR Window DnVIOLET(AC)MASTER WINDOW CONTROL SWITCH
posted_imageRR Window UpGREEN/ YELLOW(AC)MASTER WINDOW CONTROL SWITCH
posted_imageRR Window DnGREEN / WHITE(AC)MASTER WINDOW CONTROL SWITCH
posted_imageSunroof OpenGRAY/WHITE(+)AT SUNROOF SWITCH HARNESS
posted_imageSunroof CloseGRAY/BLACK(+)AT SUNROOF SWITCH HARNESS...A 1-SECOND PULSE WILL VENT DOWN, A THREE SECOND PULSE WILL CLOSE FROM FULLY OPEN.
M.E.C.P & First-Class
