door popper with 791 reduce delay
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116465
Printed Date: April 07, 2026 at 6:19 PM
Topic: door popper with 791 reduce delay
Posted By: shivanand8
Subject: door popper with 791 reduce delay
Date Posted: September 21, 2009 at 1:35 PM
i currently have a viper 791 ona toyota camry i also have a driver side door popper installed on the trunk unlock channel. it works great except i have to unlock the car (which i like) and hold down the AUX button for 5 sec.( what i dont like) Is there a way to reduce the time it take to activate channel 2?
Camry!
Posted By: i am an idiot
Date Posted: September 22, 2009 at 6:31 AM
If you use output for channel 4 or 5, do those channels have the same delay, or are they instant.  Lock and Aux are one of the channels.  Unlock and Aux is the other output.  I can only guess that these 2 channels will not have the delay.  Press and hold the Aux button and then press lock or unlock to see if 4 or 5 goes to ground.  The 5 second delay is just a safety feature so you will not accidentally open something if the button gets pressed in your pocket.  The pressing of 2 buttons at the same time is a lot more unlikely.  That should give  you instant results.
https://www.the12volt.com/installbay/downloads.asp?srch=all&term=791
Date Posted: September 22, 2009 at 11:12 AM
Thanks for the advice. channel 4 & 5, unlock instantly but u have to press two buttons at the same time. the way i have it rugged is that if u dont press the unlock button first the door isnt going to open. even when u get in the car n start moving the doors lock again. i just dont want to wait the 5 sec. but dont want to pres two buttons.
Camry!
Posted By: Mark Mizenko
Date Posted: September 22, 2009 at 2:11 PM
Can you use the 2Nd unlock output to pop the door?
Posted By: t&t tech
Date Posted: September 22, 2009 at 9:45 PM
You can program channels four or five to a single button on the remote!
Date Posted: September 23, 2009 at 12:34 PM
how would i do that?
Camry!
Posted By: t&t tech
Date Posted: September 23, 2009 at 3:05 PM
Which channel specifically would you be using? Four or five?
Date Posted: October 01, 2009 at 11:23 AM
doesnt matter!
Camry!
Posted By: t&t tech
Date Posted: October 01, 2009 at 7:35 PM
well to give you specific instructions i gotta know!
Posted By: t&t tech
Date Posted: October 01, 2009 at 7:38 PM
Ok! here's channel four! Turn ignition on, with a door open, press the valet switch six times and hold on the seventh press, when you hear the six chirps, the press the aux on the remote, the siren should emit a long chirp! This indicates success!
