Home
MOBILE
ELECTRONICS
Car Audio
Subwoofers & Enclosures
Car Security
Cruises
Diagrams
Diodes
Door Locks
Glossary
Installs
Join the Club
Links
Ohm's Law
Relays
Resistors
Tools
Search
the12volt
the12volt
About Me
Email
Guest
the12volt.com line
Subwoofer Enclosures
First Order / Infinite Baffle / Free Air
These are great for applications where trunk space is at a minimum and usually the easiest and least expensive way to add a subwoofer to most sedans. Not having to construct a box is an advantage, but many vehicles will require a new rear deck panel and/or vent to be constructed to accomodate even smaller woofers. These custom vents and panels could cost as much or more than a prefabricated or custom box.
Infinite baffle set-ups require a woofer with a beefier suspension for high power handling and one with better cone damping. This set-up will be less efficient in reproducing the lowest frequencies as compared to a second order or higher enclosure.
In any free air application, the back seat and surrounding panels should be removed to seal any possible areas where energy could be lost. It is crucial to separate (seal) the back wave of the loudspeaker (woofer) from the front wave of the loudspeaker. If not, bass cancellation will occur. This is also a good time to rid and deaden the trunk and surrounding areas of any unwanted noises and rattles.
line
Typical Rear Deck Installation
Larger sedans, especially older ones, will have enough surface area to accomodate a pair of 12 or 15 inch woofers. These will be the easiest to incorporate an infinite baffle set-up into. Don't forget to seal any areas where energy could be lost that would cause any cancellation. For smaller rear decks, a vent will have to be constructed.
Back Seat Installation
The baffle board may also be mounted behind the back seats (usually folding) instead of under the rear deck. This is often easier and less expensive than cutting the rear deck and will not require any modifications to the existing deck panel.
Small Deck Installation
Many of today's vehicles lack the surface area needed to mount a ten inch or larger woofer in the rear deck. If this is the case, it is still possible to use free air woofers by venting them through the rear deck as shown in the two diagrams below. Sealing the trunk area from the interior of the vehicle is still critical to a successful installation. Try to keep the inside dimensions of the front and rear walls of the vent at least four inches apart when working around trunk springs and other obstacles.
Another small deck configuration like the one above, but with the magnet structure mounted inside the vent.
  • Subwoofer Enclosures
  • Fraction to Decimal & Volume Calculators
  • First Order / Infinite Baffle / Free Air
  • Second Order / Acoustic Suspension / Sealed Enclosures
  • Fourth Order / Bass Reflex & Bandpass Enclosures
  • Sixth & Eighth Order / Bandpass Enclosures
  • Thiele - Small Parameters
  • Brian Steele's The Subwoofer DIY Page v1.1
  • Blaupunkt's Free BlauBox Program (DOS version - 215K)
    Car Audio Menu Glossary
    Installs
    Ohm's Law
    Passive Crossovers & Calculators
    Power and Ground Cable Sizes
    the12volt's Install Bay
    Tools & Equipment
  • the12volt.com line
