the12volt.com - Free Technical Information for Mobile Electronics Installers since 1999
the12volt.com - Free Technical Information for Mobile Electronics Installers, Enthusiasts, and Do-It-Yourselfers since 1999
BasicsCar AudioCar SecurityCruise ControlsDiodesDoor LocksOhm's LawPassive CrossoversRelaysResistorsSubwoofer Enclosures Search
Application GuidesCalculators, Charts, DiagramsDownloadsFind InstallersForumsGlossarySubwoofer WiringToolsVehicle Wiring Last 100 Forum Topics
Diodes
Ohm's Law
Relays
Resistors
Tools and Equipment
Glossary of Terms
Introduction
Metra Application Guides
Parallel & Series Calcs
Passive Crossovers
Port Length Calculators
Power & Ground Wire Sizes
Subwoofer Box Calculators
Subwoofer Enclosure Types
Subwoofer Wiring Options
Thiele - Small Parameters
Miscellaneous
The Application Guide
Vehicle Wiring Database
Introduction
Alarm Accessories
Alarm Modules
Alarm Sensors
Basic Connections
Illuminated Entry
Light Flash
Power Door Locks
Starter Interrupts
Insurance
Introduction
Electrical Connections
Mechanical Connections
Servo Settings
VSS and Tach Info
Vehicle Wiring Databse
All Forums
Buy & Sell Equipment
Car Audio
Car Security & Convenience
Cellular & Communications
Cruise Controls
Employment
Fiberglass & Fabrication
Forum Help & How To
General Discussion
Lights, Neon, LEDs, HIDs
Miscellaneous
Mobile Video & Navigation
Motorcycle Electronics
Music, Favorite Songs
Forum & Site Notices
Relays
Rides & Systems Gallery
Vehicle Information
Books & DVDs
Calculators
Charts
Diagrams
Downloads
Find an Installer
Forums - Q&A
Glossary of Terms
Insurance
Links
Mobile Tech News
About the12volt
Hurricane Katrina
Link to Us
Support Us
Car Alarms
Keyless Entry
Remote Car Starters
Power Windows
Power Door Locks
Shaved Door Handles
Headlights
Tail Lights
Body Kits
Tail Lights
Headlights
Lambo Doors
Intakes
Rims
Headers
Clutch Kits
Civic Exhaust
Wheels
Mustang Exhaust
Body Kits
Car Audio: Subwoofer Enclosures/Fourth Order
Fourth Order Single Reflex Bandpass Enclosure A fourth order enclosure (vented box) is a sealed enclosure with the additon of a port tuned to a specific frequency. The port extends the low frequency response of the basic sealed enclosure usually providing a lower cut-off frequency. The enclosure offers a good transient response (second to that of a sealed enclosure), good power handling within it's bandpass region, and excellent efficiency making it a popular choice for many competitors and everday users, but below the tuned frequency power handling is poor and damage to the woofer is likely to occur if over driven. Lowering the port frequency below that of the manufacturer's recommended frequency will only worsen matters and cause the sound to become "muddy"....bleah!
With any ported design enclosure, the largest port diameter or area should be used to minimize port noises (or whistling). Flaring the edges of the port is also recommended for the same reasons. Ports may be any shape, but a cyclinder is usually the easiest to incorporate into your design.
These enclosures are obviously more complex to build, less forgiving of design errors, and usually larger than sealed enclosures, but if done properly, they can provide that additional output a competitor desires.
Fourth Order/Bass Reflex and Bandpass Enclosures:
Fourth Order / Bass Reflex
Isobaric - Bass Reflex
Isobaric - Bass Reflex (Compound Loading)
Bass Reflex - Passive Radiator
Isobaric Bass Reflex - Passive Radiator
Single Reflex - Band Pass
Isobaric Single Reflex Bandpass
Three Chamber Single Reflex Bandpass
Isobaric Three Chamber Single Reflex Bandpass
top of page Fourth Order/Bass Reflex
Most often used in hatchbacks, vans, SUVs, and other vehciles where the enclosure can be mounted inside of the vehicle, the bass reflex enclosure is a poplular choice for competitors and the easiest of the fourth order enclosures to build. The shape of the box may vary, often seen with the facing or rear wall angled, but may be a simple box shape as shown.
top of page Isobaric - Bass Reflex
If space is at a premium or just a smaller enclosure is desired, an isobaric design may be used. The volume of the enclosure wil be approximately half the space of the above enclosure with the same results. The downside is you will need two woofers vs. one and the output will be the same.
top of page Isobaric - Bass Reflex (Compound Loading)
This is a variation of the above enclosure. As long as the woofers are mechanically in phase, it doesn't matter which way they face each other, however this will require a larger enclosure to accomodate the magnet and frame assembly of the outer woofer and is more complex to build.
top of page Bass Reflex - Passive Radiator Enclosures
Passive radiator systems are very similar to ported systems. Instead of a tuned port, a "drone cone" is used to extend the low frequency response. Most look like a flat diaphram, some may look like a woofer, but will have no magnet structure. The response is similar to a ported system, but the cut-off frequency is slightly higher, and the cut-off slope is slightly steeper. Many of you may have seen the very small enclosures made by Stillwater Designs® that used 4'' drivers with a passive radiator (not sure if they still make these). These worked extremely well (for what they were) in vehicles that literally had next to no room at all to mount a conventional enclosure inside of the vehicle (i.e.: Jaguars XJS, mounted under the seats).
top of page Single Reflex - Band Pass Enclosures
The single-reflex band pass enclosure is basically a combination of a sealed and vented enclosure. These can be fairly small enclosures, though larger than a sealed enclosure. They offer great power handling, good low frequency response, but are not as efficient as vented enclosures (top of this page), and are more complex to build. However, when built correctly, these make excellent enclosures and are often used by competitors. This is often referred to as a fifth order enclosure, but it's not. The addition of a crossover makes it a fifth order system.
Subwoofer Enclosures:
Calculators: Parallel, Series, Port Length, & Volume
Second Order / Infinite Baffle / Free Air
Second Order / Acoustic Suspension / Sealed Enclosures
Fourth Order / Bass Reflex & Bandpass Enclosures
Sixth & Eighth Order / Bandpass Enclosures
Subwoofer Wiring Configurations
Brian Steele's The Subwoofer DIY Page v1.1
  Car Audio:
Glossary of Terms and Definitions
Ohm's Law
Passive Crossovers & Calculators
Power and Ground Cable Sizes
Subwoofer Enclosures & Calculators
Subwoofer Wiring
the12volt's Application Guide
the12volt's Install Bay (forums)
Tools & Equipment
ohm's law, resistors, relays, and more
Saturday, July 04, 2009 Copyright © 1999-2009 the12volt.com Donate to the12volt.com Privacy Policy Advertising
the12volt.com - Free Technical Information for Mobile Electronics Installers, Enthusiasts, and Do-It-Yourselfers since 1999 Donate to the12volt.com
