under dash twin speaker mount
rallybug
Posted: February 20, 2014 at 11:48 AM / IP Logged
I have a 1979 VW Bus that, originally, had the option of a circa 5.5-6" diameter mono speaker in the center of the dash, pointing at the windshield:
under dash twin speaker mount -- posted image.
Obviously, a mono speaker won't cut it with a modern head unit under dash twin speaker mount -- posted image. , so although my front door panels are already cut for speakers (at ankle height), I'd like some sounds up a bit closer to my ears - I'm sure that my legs would enjoy the music, but...
I was thinking about putting a couple of 3.5" speakers onto angled bases facing outwards, but still up under the dash in the standard speaker position.
What would be the best way forwards? Normal MDF trim rings on some spacers, or making an angled mount for them?
Ben
itsyuk
Silver - Posts: 505
Posted: February 20, 2014 at 7:56 PM / IP Logged
there are a few speakers out there that have a dual voice coil woofer and seperate right and left tweeters. custom autosound sells some ovals.
surely someone has round ones.
have you looked for that type of speakers?
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
rallybug
Posted: February 20, 2014 at 8:16 PM / IP Logged
I haven't, no - I suppose that even an oval of a small enough size would work, if there's no round one.
Ben
itsyuk
Silver - Posts: 505
Posted: February 20, 2014 at 8:27 PM / IP Logged
like this ...
search ebay for ."dvc stereo speakers"
i dont know how much room you have .... if these tweets stick out too much.
yuk
itsyuk
Silver - Posts: 505
Posted: February 20, 2014 at 8:37 PM / IP Logged
http://vintagevibes.net/volkswagen.htm has one for vw dashes... dont know if its the same size you need.
part number 31005DVC was the one on ebay i saw. its a 5 inch.
yuk
bellsracer
Silver - Posts: 703
Posted: April 07, 2014 at 8:36 AM / IP Logged
It would be better to keep the speakers down lower. It's a matter of audio imaging. The more equal distance the speakers are from your ears, then the better the sound balance will be. Under the dash in the center loses stereo sound and makes it sound like it is a mono speaker still. Being that much closer isn't going to affect the quality of sound as much as being louder.
I personally like the ankle area. If you measure out the distances, the kick panels are RELATIVELY the same distance from the ears.
Ganbatte ne!
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
