amp wattage vs ohms
h2ss
Posted: July 14, 2014 at 2:59 PM / IP Logged
Hello,
I am building a home subwoofer but am unsure of what type of amplified plate I need to order.
The speaker is a Rokford Fosgate P2 rated at 250w RMS - 500w Peak, DVC at 2 ohms. Now most of the amps are rated at 4ohms. If I run the sub in series at a 4 ohm, what will be my new RMS and Peak wattage?
the12volt
Administrator - Posts: 3,955
Posted: July 14, 2014 at 3:23 PM / IP Logged
The same.
amp wattage vs ohms -- posted image. the12volt • Support the12volt.com
h2ss
Posted: July 14, 2014 at 3:30 PM / IP Logged
So a resistance changed doesn't equal wattage change?
h2ss
Posted: July 14, 2014 at 3:36 PM / IP Logged
I should ask it this way...because I am not powering two voice coils at 2ohms with to separate channels at 250 watts each, do I now want to power both together with a 500w amp at 4 ohms? As you can see I am bit lost.
the12volt
Posted: July 14, 2014 at 4:09 PM / IP Logged
Wiring in parallel versus series will change the load on the amplier. In turn it can change the amount of power produced by the amplier at 1 ohm vs. 4 ohms, if the amplier can safely run at one ohm. Regardless of how you wire the two coils to an amplier, the power handling of the woofer remains the same. Your best bet is to wire them in series to a mono amplier rated at 250 watts at 4 ohms.
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
