2014 Toyota Tacoma Prerunner Alarm/Remote Start/Stereo Wiring
cj10
Member - Posts: 48
Posted: August 28, 2014 at 3:26 AM / IP Logged
I plan to buy the truck within a month and want to install my own alarm system. It will be a V6, 5 speed AT. I don't plan to install the remote start so my wiring should be fairly simple. Can anyone show me where i can get the alarm wiring for this vehicle with pictures? I'm not sure if the wiring would be the same as the 2013 and 2013 tacomas.
Mahalo in advance.
cj
tonanzith
Gold - Posts: 593
Posted: August 30, 2014 at 9:57 AM / IP Logged
Item     Wire Color     Polarity     Wire Location
12 Volts     WHITE/ red (30A)     +     ignition switch, white 8 pin plug, pin 5
Second 12 Volts     WHITE/ blue (50A)     +     ignition switch, white 8 pin plug, pin 4
Starter     GREEN/ black     +     ignition switch, white 8 pin plug, pin 7
Second Starter     BLACK/ white     +     ignition switch, white 8 pin plug, pin 3
Ignition     BLACK/ red     +     ignition switch, white 8 pin plug, pin 6
Second Ignition     blue / YELLOW     +     ignition switch, white 8 pin plug, pin 1
Third Ignition     N/A
Accessory     WHITE/ green     +     ignition switch, white 8 pin plug, pin 2
Second Accessory     N/A
Third Accessory     N/A
Keysense     GREEN/ black     -     ignition key switch, white 2 pin plug, pin 1
Data Bus     pink/green (RX), lt. GREEN/ red (TX)     data     Transponder Key Amplifier, black 7 pin plug, pins 4 and 5
The immobilizer light is PURPLE / white (+) at the light, white 14 pin plug, pin 6. The IMO - IMI are lt. GREEN/ black - blue/white at the Engine Control Module behind glove box, black 36 pin plug (E22/E14, second plug from bottom), pins 32 and 31 (4 cylinder), or pins 20 and 14 (6 cylinder).
Can Bus High     yellow/black     data     data link connector, white 16 pin plug, pin 6
Can Bus Low     blue/white     data     data link connector, white 16 pin plug, pin 14
Can Bus Sw     N/A
Power Lock     blue/white     -     driver kick, gray 10 pin plug, pin 6
This wire is only needed if the door locks do not function with the aftermarket system while the vehicle is running. All other times just use the factory alarm arm wire.
Power Unlock     gray     -     driver kick, gray 10 pin plug, pin 7
This wire is only needed if the door locks do not function with the aftermarket system while the vehicle is running. All other times just use the factory alarm disarm wire.
Lock Motor     blue/red     5 wire     driver kick, white 12 pin plug, pin 10 or black 8 pin plug, pin 6
Driver Unlock Motor     blue/black     5 wire     driver kick, gray 10 pin plug, pin 9
Passenger Unlock Motor     blue/black     5 wire     dash fuse box, rear, white 24 pin plug (1H), pin 5
Parking Lights (-)     green     -     headlight switch, white 20 pin plug, pin 18
Parking Lights (+)     green     +     dash fuse box, white 13 pin plug (1D), pin 10
Hazards     RED / white     -     hazard switch, white 14 pin plug, pin 9
Turn Signal (Left)     yellow (F); yellow (R) (common on models w/o DRL)     +     dash fuse box, wht 11 pin plg (1B), pin 7; wht 13 pin plg (1D), pin 11
Turn Signal (Right)     lt. blu (F); blu/wht (R)(common on models w/o DRL)     +     dash fuse box, wht 11 pin plg (1B), pin 5; wht 13 pin plg (1D), pin 4
Headlight     pink     -     headlight switch, white 20 pin plug, pin 20
AutoLights     N/A
Reverse Light     red     +     driver kick, gray 12 pin plug, pin 1
Left Front Door Trigger     GREEN/ YELLOW     -     dash fuse box, white 18 pin plug (1F), pin 7
Right Front Door Trigger     RED / black     -     dash fuse box, rear, white 22 pin plug (1I), pin 8
Left Rear Door Trigger     pink/black     -     dash fuse box, white 18 pin plug (1F), pin 6
Right Rear Door Trigger     same as left rear door trigger
Dome Supervision     blue     -     dash fuse box, black 13 pin plug (1E), pin 9
Trunk/Hatch Pin     N/A
Rear Glass Pin     N/A
Hood Pin     N/A
Trunk/Hatch Release     N/A
Trunk Release Motor     N/A
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     purple (driver door key lock)     -     driver kick, gray 10 pin plug, pin 4
Factory Alarm Disarm     GREEN/ black (driver door key unlock)     double -     driver kick, gray 10 pin plug, pin 8
Disarm No Unlock     use keysense
Trunk Alarm Shunt     N/A
Tachometer     BLACK/ white     ac     data link connector, white 16 pin plug, pin 9
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     BLACK / YELLOW     +     clutch switch, black 2 pin plug, pin 2
Fuel Pump     BLACK/ red     +     driver kick, white 18 pin plug, pin 8
Rear Defroster     N/A
Mirror Defroster     N/A
Left Front Heated Seat     purple     + resistor     driver kick, white 18 pin plug, pin 4
Right Front Heated Seat     purple     + resistor     passenger kick, gray 11 pin plug, pin 2
Speed Sense     PURPLE / white     ac     dr kick junc box, wh 20 pin plg, pin 10, or radio, wh 28 pin plg, pin 17
Brake Wire     blue     +     dash fuse box, white 13 pin plug (1D), pin 13
Parking Brake     GREEN/ YELLOW     -     dash fuse box, white 18 pin plug (1C), pin 5
Horn Trigger     GREEN/ red     -     dash fuse box, white 18 pin plug (1C), pin 10
Wipers     blue/black (low), blue/red (high), blue (ignition)     +     wiper switch, white 10 pin plug, pins 3, 4, and 2
Left Front Window (Up/Down)     blue - blue/black     A     power window master switch, white 18 pin plug, pins 10 - 12, or 3 - 4
Right Front Window (Up/Down)     blue / YELLOW - black     A     driver kick, white 12 pin plug, pins 2 and 3
On double cab models, they are in the driver kick, white 7 pin plug, pin 4, and black 8 pin plug, pin 2.
Left Rear Window (Up/Down)     GREEN / WHITE - GREEN/ red     A     driver kick, white 7 pin plug, pins 6 and 5
Right Rear Window (Up/Down)     GREEN/ black - green     A     driver kick, black 8 pin plug, pins 7 and 3
Sun Roof (Open/Close)     N/A
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     WHITE/ blue     +     radio, white 10 pin plug, pin 4
Radio Ground     brown     -     radio, white 10 pin plug, pin 7
Radio Ignition     gray     +     radio, white 10 pin plug, pin 3
Radio Illumination     green (parking lights); GREEN / WHITE (dimmer)     +,-     radio, white 10 pin plug, pin 10; blue 6 pin plug, pin 5
Factory Amp Turn-on     N/A
Power Antenna     N/A
Left Front Speaker (+/-)     pink - purple     +,-     radio, white 10 pin plug, pins 2 - 6
On models with amplifier, the speaker wires are pink - purple at the amplifier on right rear cabin wall, white 12 pin plug, pins 2 - 1. The tweeter wires are RED / white - red at the amplifier, blue 10 pin plug, pins 8 - 7.
Right Front Speaker (+/-)     lt. green - blue     +,-     radio, white 10 pin plug, pins 1 - 5
On models with amplifier, the speaker wires are lt. green - blue at the amplifier on right rear cabin wall, white 12 pin plug, pins 9 - 3. The tweeter wires are blue - pink at the amplifier, blue 10 pin plug, pins 2 - 6.
Left Rear Speaker (+/-)     black - yellow     +,-     radio, blue 6 pin plug, pins 2 - 6
On models with amplifier, the speaker wires are black - yellow at the amplifier on right rear cabin wall, blue 10 pin plug, pins 3 - 9.
Right Rear Speaker (+/-)     red - white     +,-     radio, blue 6 pin plug, pins 1 - 3
On models with amplifier, the speaker wires are red - white at the amplifier on right rear cabin wall, blue 10 pin plug, pins 10 - 4.
Center Channel (+/-)     N/A
Subwoofer (+/-)     (paralleled with rear speakers)
On models with amplifier, the speaker wires are GREEN/ YELLOW - GREEN / WHITE (1); blue/black - blue/red (2) at the amplifier on right rear cabin wall, white 12 pin plug, pins 5 - 12; 4 - 10.
Aux. Audio Input Left (+/-)     white - red     +,-     radio, white 28 pin plug, pins 28 - 27
Aux. Audio Input Right (+/-)     black - red     +,-     radio, white 28 pin plug, pins 26 - 27
RSE Video (+/-)     red - white (rear view camera)     +,-     radio, white 24 pin plug, pins 12 - 24
RSE Audio Left (+/-)     N/A
RSE Audio Right (+/-)     N/A
Satellite Radio 12 Volts     red     +     satellite radio below radio, wht 8 pin plug, pin 4
Satellite Radio Ground     black     -     satellite radio below radio, wht 8 pin plug, pin 8
Satellite Radio Ignition     yellow     +     satellite radio below radio, wht 8 pin plug, pin 3
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     (DIN cable)
Satellite Audio Right (+/-)     (DIN cable)
Item     Size     Depth     Location
Headunit     irregular center of dash
Left Front Speaker     6.3 or 6 x 9 left front door
Left Front Tweeter     2.6 left front door
Right Front Speaker     6.3 or 6 x 9 right front door
Right Front Tweeter     2.6 right front door
Left Rear Speaker     6.3 or 3.1 left rear door
Left Rear Tweeter     1.6 left rear ceiling (access cab)
Right Rear Speaker     6.3 or 3.1 right rear door
Right Rear Tweeter     1.6 right rear ceiling (access cab)
Center Channel     N/A
Subwoofer     6.3 (access cab), or 7.9 (double cab) rear cabin wall
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner   below radio
Gary Sather
daflipcyde
Copper - Posts: 68
Posted: October 20, 2014 at 10:45 AM / IP Logged
Using Viper 4204 how do you hook up Starter 1 and 2 and Ignition 1 and 2?
catback
Silver - Posts: 703
Posted: October 20, 2014 at 11:42 AM / IP Logged
You would use the flex relay output for ignition 2, and H2/18 violet / YELLOW in conjunction with a relay for starter 2.
Thursday, April 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
