2014 mercedes c-class
pyrozman29
Posted: December 11, 2014 at 10:23 AM / IP Logged
Needing wiring diagram and anti theft information for a Mercedes c-class to install remote starter.
Zman
tonanzith
Gold - Posts: 593
Posted: December 16, 2014 at 2:11 PM / IP Logged
Tip start? Push to start? And it should only have a stand alone solution from directed or idatalink which should come pre flashed and with mostly t harnesses.
Gary Sather
Posted: December 18, 2014 at 6:48 PM / IP Logged
X 2 with tonanzith, Anti theft will only work through their databus systems.
In other words you can't hardwire it.
You need a specialised R/S module from Firstech etc.
I've recently learned how to immobilise them though.
Look for either a RED / violet or WHITE/ red wire going to an ignition switch plug.
In the first case this will cut power to ignition, in the second place will disable the internal ignition solenoid thus the key can't be turned.
Applies to "magic key" vehicles, not PTS.
Tried and tested on late E class (2013/14 yr.) European spec vehicles.
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
