2003 Chevrolet Trailblazer Alarm/RS/Stereo Wiring
biggest424
Member - Posts: 10
Posted: November 06, 2003 at 11:03 AM / IP Logged
hi,i am looking for the wire diagrams for the 2003 chevy trailblazer LS model 2wd.i need this wire sheet to install the hornet 554t remote start alarm.
glen
Z32tt
Member - Posts: 17
Posted: November 10, 2003 at 12:08 AM / IP Logged
|              12V|red  (x2)           |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|use Directed module |   |                            |
|     POWER UNLOCK|part #455G *3       |   |                            |
|       LOCK MOTOR|gray                |   |driver door module in door  |
|     UNLOCK MOTOR|tan                 |   |driver door module in door  |
|    DISARM DEFEAT|tan                 |   |relay box under rear seat   |
| PARKING LIGHTS +|brown               |   |driver kick panel           |
| PARKING LIGHTS -|gray/black          |   |headlight switch            |
|       HEADLIGHTS|white               |-  |headlight switch            |
|     DOOR TRIGGER|gray/black          |+  |underdash lt or dri A pillar|
| DOME SUPERVISION|comes on with disarm|   |                            |
|  TRUNK/HATCH PIN|pink/black *1       |-  |liftgate module             |
|         HOOD PIN|pink/black          |-  |pin switch or BCM           |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|lt. green           |-  |driver door module in door  |
|       TACHOMETER|white               |   |blue plug, pin 49 @ PCM *2  |
|      SPEED SENSE|GREEN / WHITE         |   |blue plug, pin 32 @ PCM *2  |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black or blk/yel    |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|blue - brown        |A  |driver door module          |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |front passenger door module |
|  LR WINDOW UP/DN|blue - brown        |A  |LR window switch            |
|  RR WINDOW UP/DN|blue - brown        |A  |RR window switch            |
| SUN RF OPN/CLOSE|blue/red - blue     |A  |sun roof motor              |
|        RADIO 12V|orange              |+  |radio                       |
|     RADIO GROUND|BLACK/ white         |-  |radio                       |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|BROWN / white (dimmer)|+  |radio                       |
|    POWER ANTENNA|gray                |+  |radio                       |
|       LF SPEAKER|tan - gray          |   |radio                       |
|       RF SPEAKER|lt. green - green   |   |radio                       |
|       LR SPEAKER|brown - yellow      |   |radio                       |
|       RR SPEAKER|blue - lt. blue     |   |radio                       |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555L.  *1 The liftgate glass ajar switch wire is purple. It is also located at the liftgate module in the liftgate.  *2 The PCM (Powertrain Control Module) is on the driver side of the motor.  *3 If Directed module part #455G is not available, refer to directfax document #1053.
biggest424
Member - Posts: 10
Posted: November 10, 2003 at 5:13 AM / IP Logged
thanks alot z32tt
glen
biggest424
Member - Posts: 10
Posted: November 10, 2003 at 3:14 PM / IP Logged
hi z32tt,could you fax me the direct fax document #1053 for the directed module part#455G.
or email it to me at morganheights@caribsurf.com
thanks
Thursday, March 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
