2001 Cadillac Deville Alarm/Remote Start Wiring
Moderator - Posts: 12,488
Posted: August 07, 2004 at 6:55 PM / IP Logged
|              12V|orange or orn/blk *1|+  |ignition harness            |
|          STARTER|purple or yellow    |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|RED / black           |-  |drivers door lock switch    |
|     POWER UNLOCK|ORANGE / black        |-  |drivers door lock switch    |
|       LOCK MOTOR|gray                |   |drivers door module *2      |
|     UNLOCK MOTOR|tan                 |   |drivers door module *2      |
|    DISARM DEFEAT|tan                 |   |passenger door module *3    |
| PARKING LIGHTS +|do not use          |   |                            |
| PARKING LIGHTS -|BROWN / white         |   |DIM module *4               |
|       HEADLIGHTS|white               |-  |DIM module *4               |
|     DOOR TRIGGER|*5                  |-  |*5                          |
| DOME SUPERVISION|gray                |-  |underdash light             |
|  TRUNK/HATCH PIN|ORANGE / black        |-  |trunk light                 |
|TRNK/HTCH RELEASE|BLACK/ white *10     |-  |under the rear seat *6      |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|lt. green           |-  |drivers door module *2      |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|PURPLE / white        |   |ign. coil on top of motor   |
|      SPEED SENSE|GREEN / WHITE         |   |cruise control module *7    |
|       BRAKE WIRE|white               |+  |low in drivers kick         |
|     HORN TRIGGER|black               |-  |DIM module *4               |
|           WIPERS|white               |+  |DIM module *4               |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |drivers door module *2      |
|  RF WINDOW UP/DN|dk. blue - brown    |A  |passenger door module *3    |
|  LR WINDOW UP/DN|dk. blue - brown    |A  |LR door module              |
|  RR WINDOW UP/DN|dk. blue - brown    |A  |RR door module              |
| SUN RF OPN/CLOSE|dk. grn - lt. grn   |A  |sunroof motor *8            |
|   SUN ROOF LIMIT|red                 |-  |sunroof motor *8            |
|        RADIO 12V|orange              |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
| RADIO ILLUMINATE|yellow/black        |*9 |radio                       |
Notes:
NOTE: This vehicle is equipped with the pass-key III immobilizer. Use DEI part number 555G or 555U to bypass.  *1 This is a low current 12V source that should not be used to drive any high current positive circuits.  *2 The drivers door module is located above the speaker in the drivers door.  *3 The passengers door module is located above the speaker in the passenger door.  *4 The DIM module is located just in front of the blower motor near the passenger kick. It has three connectors that all exit out of the bottom of the module. All wires are located in the ceter plug except for the horn trigger wire which is located in the right side plug.  *5 The drivers door trigger wire is tan at the drivers door module, and the other door triggers are dk. blue at their respective door modules.  *6 At the fuse/relay block.  *7 The cruise control module is located under the hood on the drivers side inner fender.  *8 The sunroof motor is located to the rear of the sunroof towards the top center of the rear window.  *9 Power varies with the interior light volume.  *10 The fuel door release is white, negative trigger, located under the rear seat at the fuse/relay block.
Thursday, March 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
