DIRECTWIRE™ WIRING INFORMATION - PONTIAC / GRAND AM / 1999 / Remote Start
12volts red + ignition harness
Notes: Remove the radio, without unplugging it, to access the ignition harness.
Starter yellow + ignition harness
Second Starter
Ignition pink + ignition harness
Second Ignition dk. green + ignition harness
Third Ignition
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Keysense
Power Lock white - black plug in dkp
Notes: Lock requires a negative trigger, and unlock requires a negative trigger through a 1,500 ohm resistor. Must use relays. Must close doors to lock with a single pulse.
Power Unlock same wire
Lock Motor gray drivers kick panel
Unlock Motor tan drivers kick panel
Parking Lights+ brown passenger kick or column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger -
Notes: The lt. GREEN/ black is located in the drivers kick and catches only the drivers door. The lt. blue is located in the harness coming from the drivers running board going under the drivers seat and it catches all other doors. Use both door trigger wires and diode isolate each. On the 2 door the lt.blue is in the passenger kick.
Dome Supervision white - dash light or column
Trunk/Hatch Pin ORANGE / black - trunk light
Hood Pin
Trunk/Hatch Release BLACK/ white + drivers kick panel
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer white or PURPLE / wht ignition coil or ECM
Notes: The ECM is located under the left side of the dash to the left of the column.
Wait to start
Brake Wire lt. blue + at the switch
Parking Brake
Horn Trigger black - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 457G, 555L, or 555T
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.
