2002 dodge ram 1500 alarm wiring
pfunkdzyne
Posted: March 31, 2005 at 12:49 AM / IP Logged
does anyone have the alarm wiring diagram for the 2002 dodge ram 1500, I mainly need the color and location of the door and dome light wire.
I walk with the king
thepencil
Gold - Posts: 1,526
Posted: March 31, 2005 at 9:10 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - DODGE / RAM PICKUP / 2002 / Remote Start
12volts pnk/blk & RED / wht   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition blue (16 awg)   +   ignition harness
Second Ignition red or RED / wht   +   ignition harness
Third Ignition N/A
Accessory green & orange   +   ignition harness
Second Accessory blue & blk/wht   +   ignition harness
Notes: These wires may not be necessary for remote start.
Keysense lt. blue   -   ignition harness
Power Lock WHITE/ green   -   driver kick panel
Notes: Lock requires a negative trigger thru a 820 ohm resistor. Unlock requires a negative trigger thru a 330 ohm resistor. MUST use relays.
Power Unlock same wire as power lock
Lock Motor tan/pnk or tan/blk      driver kick panel
Unlock Motor blue      driver kick panel
Parking Lights+ BLACK / YELLOW      relay under hood at pwr ctr
Parking Lights- purple / YELLOW      headlight switch
Notes: Parking lights require a negative trigger thru a 330 or 1.4K ohm resistor. Headlights require a negative trigger thru a 1.8K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light PURPLE / black   +   automatic day/night mirror
Door Trigger     -
Notes: The LF door trigger is tan, and the LR door is tan/orange or PURPLE / orange. These wires are in the driver kick panel. The RF door trigger is tan/red, and the RR door is tan / YELLOW. These wires are in the passenger kick panel. Use all wires and diode isolate each. See DirectFax document 1076 for wiring information.
Dome Supervision use door trigger
Trunk/Hatch Pin N/A
Hood Pin
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm lt. GREEN/ orange   -   driver kick panel
Notes: This will also do door locks. Arm/lock is negative trigger thru a 2K ohm resistor. Disarm/unlock is negative trigger thru a 480 ohm resistor. Single pulse will do disarm without unlocking the doors. Unlock requires a double pulse. MUST use relays.
Factory Alarm Disarm same wire as alarm arm
Disarm No Unlock
Tachometer NOT GREEN/ orange   ac   ign coil, coil pack, or injector
Wait to start see notes
Notes: The 2002 Ram Diesel Pickups were carried over from the old body style. Refer to the 2001 Ram Pickup for wiring information.
Brake Wire WHITE/ tan   +   brake pedal switch
Parking Brake WHITE/ lt. green   -   parking brake switch
Horn Trigger BLACK/ red   -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Sentry Key Part #: 555C, 556U, or 555U
Notes: Only vehicles with gray keys have the immobilizer.
Be careful whose advice you buy, but be patient with those who supply it.2002 dodge ram 1500 alarm wiring -- posted image.
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
