DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES SUPER DUTY / 2005 / Remote Start
12volts yellow (30A), lt grn/pur (30A) + ignition harness
Starter dk. green + ignition harness
Second Starter N/A
Ignition RED / lt. green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW and RED / black + ignition harness
Second Accessory dk. blue/lt. green + ignition harness
Keysense BLACK/ pink - ignition harness
Power Lock pink / YELLOW (w/o keyless) 5wi driver kick, door harness
Notes: Vehicles with keyless entry, the lock wire is WHITE/ red (-), in the driver kick, door harness or also at the VSM, gray plug, pin 3.
The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Power Unlock pink/lt. green (w/o keyless) 5wi driver kick, door harness
Notes: Vehicles with keyless entry, the unlock wire is BLACK/ white (-), in the driver kick, door harness or also at the VSM, gray plug, pin 2.
Vehicles with keyless entry the VSM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1094.
Lock Motor pink/black 5wi driver kick or VSM, gray plug, pin 1
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock Motor RED / orange 5wi driver kick or VSM, gray plug, pin 7
Parking Lights+ brown + switch or VSM, green plug, pin 2
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) + turn signal switch
Turn Signal(R) wht/lt blu (F), org/lt blu (R) + turn signal switch
Reverse Light BLACK/ pink + back of fuse box, black 8 pin plug
Door Trigger use dome supervision wire
Dome Supervision BLACK/ lt. blue + pass kick or cluster, blu plg, pin26
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT RED / lt green or RED / yellow ac any ignition coil or fuel injector
Notes: On diesel vehicles the tach wire is lt. GREEN / WHITE in a 5 wire harness held up with white tape behind the parking brake release.
Wait to start see DirectFax document 1091
Brake Wire lt. green + brake pedal switch
Parking Brake lt. GREEN/ red - switch or cluster, blue plug, pin 18
Horn Trigger dk. blue - switch or VSM, green plug, pin 6
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.
