02 Saturn Vue Alarm/Remote Start/Stereo Wiring
Derek
Copper - Posts: 83
Posted: December 20, 2002 at 3:48 PM / IP Logged
Yesterday I asked if anyone had specs on a 03 Vue...No Luck . 02 Saturn Vue Alarm/Remote Start/Stereo Wiring -- posted image.  But someone called "themagicone" said it was the same as the 02...So, can someone give me any information on the 02 Vue? I've never done a Vue and like to gain some insight. (I have one coming in tomorrow!)
themagicone
Silver - Posts: 325
Posted: December 20, 2002 at 3:52 PM / IP Logged
hope this helps
this is a 2003 diagram, just go into the database bout 2 days ago!
|              12V|orange              |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|lt grn (key sense)*1|-  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|RED / black           |+  |gray 16 pin plug @ BCM *2   |
|     POWER UNLOCK|ORANGE / black *3     |+  |gray 16 pin plug @ BCM *2   |
|       LOCK MOTOR|gray                |5wi|driver kick, door harness   |
|     UNLOCK MOTOR|tan                 |5wi|driver kick, door harness   |
|    DISARM DEFEAT|tan                 |5wi|base of driver B pillar     |
| PARKING LIGHTS +|brown               |   |gray 24 pin plug @ BCM *2   |
|       HEADLIGHTS|blue                |-  |gray 16 pin plug @ BCM *2   |
|     DOOR TRIGGER|gry/blk(L),blk/wht(R|-  |gry 24 pin plug @ BCM *2, *4|
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|RED / black           |-  |gray 24 pin plug @ BCM *2   |
|  FCTRY ALARM ARM|factory remote      |   |*5                          |
|FCTRY ALRM DISARM|factory remote      |   |*5                          |
| DISARM NO UNLOCK|disarms w/rem. start|   |                            |
|       TACHOMETER|NOT pnk or blk/wht  |   |ignition coil pack          |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|lt. blue            |+  |brake pedal switch          |
|     HORN TRIGGER|black               |-  |pink 24 pin plug @ BCM *2   |
|           WIPERS|green (L), purple(H)|+  |steering column             |
|  LF WINDOW UP/DN|blue - brown        |A  |switch on center console    |
|  RF WINDOW UP/DN|green - purple      |A  |switch on center console    |
|  LR WINDOW UP/DN|blue - brown        |A  |switch on center console    |
|  RR WINDOW UP/DN|lt. green - purple  |A  |switch on center console    |
| SUN RF OPN/CLOSE|green - lt. green   |A  |sunroof motor *6            |
|   SUN ROOF LIMIT|red                 |-  |sunroof motor               |
|        RADIO 12V|orange              |+  |radio                       |
|     RADIO GROUND|BLACK/ white         |-  |radio                       |
|     RADIO SWITCH|yellow              |+  |radio                       |
| RADIO ILLUMINATE|brown *7            |+  |radio                       |
|       LF SPEAKER|tan - gray          |   |radio                       |
|       RF SPEAKER|lt. green - green   |   |radio                       |
|       LR SPEAKER|brown - yellow      |   |radio                       |
|       RR SPEAKER|blue - lt. blue     |   |radio                       |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L.  *1 The lt. green key sense wire at the steering column must see a ground during remote start to keep the SERVICE light from coming on. This wire is also found in pin A11, gray 24 pin plug @ BCM.  *2 The BCM (Body Control Module) is in the center of the dash behind the pocket.  *3 To unlock just the driver door use a lt. green (+) wire in pin A2, gray 16 pin plug @ BCM.  *4 The driver door trigger is gray/black in pin B2. The passenger door trigger is BLACK/ white in pin A12. Use both wires and diode isolate each.  *5 The factory alarm is programmable for Active, Passive (5 minute delay), or Disabled. Turn ignition on, press PANIC button 8 to 10 times in 5 seconds. Within 3 seconds press UNLOCK button for Disabled, LOCK button for Active, or LOCK button twice for Passive.  *6 The motor wire colors may be backwards, use a meter to verify.  *7 Gray wire at the radio varies with the dimmer switch.
Derek
Copper - Posts: 83
Posted: December 20, 2002 at 4:42 PM / IP Logged
You are the MAGIC ONE !02 Saturn Vue Alarm/Remote Start/Stereo Wiring -- posted image.
THANKS A MILLION!!
Thursday, April 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
