2006 Toyota 4Runner Audio Diagram
lettieri36
Posted: November 15, 2006 at 10:42 AM / IP Logged
I need the wiring diagram for the factory head unit.  non/jbl v6 4wd
i am going nuts.  i ordered it on pay pal and never recieved it.
lettieri36
lettieri36
Posted: November 15, 2006 at 10:43 AM / IP Logged
 it is a 06 4runner
lettieri36
thepencil
Gold - Posts: 1,526
Posted: November 15, 2006 at 10:49 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / 4RUNNER / 2006 / Audio
Radio 12v blue / YELLOW   +   radio harness
Radio Ground brown   -   radio harness
Radio Ignition gray   +   radio harness
Radio Illumination green   +   radio harness
Factory Amp Turn-on N/A
Power Antenna black   +   radio harness
LF Speaker +/- pink - purple   +,- radio harness or amplifier
Notes: If equipped, the stereo amplifier is behind the passenger side quarter panel.
RF Speaker +/- lt. green - blue   +,- radio harness or amplifier
LR Speaker +/- black - yellow   +,- radio harness or amplifier
RR Speaker +/- red - white   +,- radio harness or amplifier
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
Smart Starter Kill Relays: Not Available
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Be careful whose advice you buy, but be patient with those who supply it.2006 Toyota 4Runner Audio Diagram -- posted image.
lettieri36
Posted: November 15, 2006 at 10:55 AM / IP Logged
Thank you I appreciate that.
lettieri36
KarTuneMan
Platinum - Posts: 7,056
+12V DC Battery(Constant)Blue / YELLOW  Radio 1 20 amp Fusebox on left side of engine compartment
Switched AccessoryGray  Acc 7.5 amp Fusebox under dash
Ground Brown
Power Antenna Black
Illumination Green & WHITE/ green
Mute Pink
Steering Wheel Control Wire Violet/white, yellow/black & WHITE/ red
Left Front + Pink To pin 4 of left squaker, as RED / blue, then out at 2 as pink.
Left Front - Violet To pin 3 of left squaker, as blue, then out at 1 as violet.
Right Front + Light green To pin 4 of right squaker as red, then out at 2 as light green.
Right Front - Blue To pin 3 of right squaker as white, then out at 1 as blue.
Left Rear + Black
Left Rear - Yellow
Right Rear + Red
Right Rear - White
 AT SPEAKERS
Wire FunctionColorNote
Left Front Mid + Pink
Left Front Mid - Violet
Left Front Tweeter + Light green
Left Front Tweeter - Blue
  Available Notes
Notes
System has rear audio controls located in the top center of the roof.
Additional Notes
N/A
N/A
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
