DIRECTWIRE™ WIRING INFORMATION - HYUNDAI / ACCENT / 2006 / Remote Start
[PRINT THIS PAGE]
12volts green (40A), blue (30A) + ignition harness
Starter white + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory yellow + ignition harness
Keysense blue + ign harn or BCM, 20 pin plug, pin 6
Notes: The BCM (Body Control Module) is to the right of the steering column.
Power Lock blue - DKP or fuse box, 16 pin plug, pin 6
Notes: Also found yellow at the BCM, 24 pin plug, pin 13. The BCM (Body Control Module) is to the right of the steering column.
Power Unlock yellow/black - DKP or fuse box, 16 pin plug, pin 16
Notes: Also found at the BCM, 24 pin plug, pin 1. The BCM (Body Control Module) is to the right of the steering column.
Lock Motor gray 5wi DKP or fuse box, 14 pin plug, pin 5
Unlock Motor pink 5wi driver kick, blue 42 pin plug, pin 1
Notes: Also found at the BCM, 24 pin plug, pin 18. The BCM (Body Control Module) is to the right of the steering column.
Parking Lights+ GREEN/ blk (L), yellow/blk (R) + DKP or fusebox, 14 pin plg, pins 9,8
Parking Lights- red - switch or BCM, 20 pin plug, pin 12
Hazards blue/black - BCM, 24 pin plug, pin 4
Turn Signal(L) yellow/orange + turn signal switch
Turn Signal(R) BROWN / orange + turn signal switch
Reverse Light WHITE/ black + DKP or fuse box, 14 pin plug, pin 10
Door Trigger green - driver kick, blue 42 pin plug, pin 2
Notes: Also found at the BCM, 20 pin plug, pin 2. The BCM (Body Control Module) is to the right of the steering column.
Dome Supervision green - BCM, 24 pin plug, pin 12
Trunk/Hatch Pin GREEN/ orange - driver kick, blue 42 pin plug, pin 3
Notes: Also found at the BCM, 20 pin plug, pin 10. The BCM (Body Control Module) is to the right of the steering column.
Hood Pin brown - pin sw or BCM, 20 pin plug, pin 17
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm yellow/orange - driver kick, blue 42 pin plg, pin 35
Notes: Meter this wire while turning the key in the driver door key cylinder.
Also found at the BCM, 20 pin plug, pin 19. The BCM (Body Control Module) is to the right of the steering column.
Factory Alarm Disarm WHITE/ black - driver kick, blue 42 pin plg, pin 33
Also found at the BCM, 20 pin plug, pin 4. The BCM (Body Control Module) is to the right of the steering column.
Disarm No Unlock with ign, acc, and key sense
Tachometer green ac L of fusebox, wht 42 pin plg, pin 32
Notes: Also found at the instrument cluster, 16 pin plug, pin 10.
Can also go to any fuel injector and use the wire that is NOT brown.
Wait to start N/A
Brake Wire green or orange + sw or fuse box, 14 pin plug, pin 11
Parking Brake GREEN/ orange - sw or fuse box, 14 pin plug, pin 1
Horn Trigger blue - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
