Hey Jeff Please Help/ 01 Aztec
mike swanson
Copper - Posts: 290
Posted: February 13, 2003 at 12:49 PM / IP Logged
does anybody have a wire diagram for a 2001 Pontiac Aztec for a remote start
Moderator - Posts: 12,488
Posted: February 13, 2003 at 1:39 PM / IP Logged
|              12V|orange              |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|green               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|RED / black           |*1 |pink plug at BCM *2         |
|     POWER UNLOCK|same wire as lock   |-  |pink plug at BCM *2         |
|       LOCK MOTOR|gray                |   |back of fuse box, blk plug  |
|     UNLOCK MOTOR|tan                 |   |back of fuse box, blk plug  |
|    DISARM DEFEAT|tan                 |   |back of fuse box, blk plug  |
| PARKING LIGHTS +|DO NOT USE          |   |                            |
| PARKING LIGHTS -|lt blue             |   |headlight switch            |
|       HEADLIGHTS|yellow              |-  |headlight switch            |
|     DOOR TRIGGER|blue/white          |-  |pink plug at BCM *2         |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|pink/black *3       |-  |pink plug at BCM *2         |
|TRNK/HTCH RELEASE|WHITE/ black         |-  |16 pin gray plug at BCM *2  |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|purple              |-  |pink plug at BCM *2         |
|       TACHOMETER|PURPLE / white        |   |ignition coil               |
|      SPEED SENSE|green               |4  |16 pin gray plug at BCM *2  |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|green (L), purple(H)|+  |steering column             |
|  LF WINDOW UP/DN|blue - brown        |A  |drivers window switch       |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|green - purple      |A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|lt. green - purple  |A  |drivers switch or kick panel|
| SUN RF OPN/CLOSE|blue - green        |A  |sun roof motor              |
|        RADIO 12V|orange              |+  |radio                       |
|     RADIO GROUND|BLACK/ white         |-  |radio                       |
| RADIO ILLUMINATE|gray        (dimmer)|+  |radio                       |
|       LF SPEAKER|tan - gray          |   |radio                       |
|       RF SPEAKER|lt. green - green   |   |radio                       |
|       LR SPEAKER|brown - yellow      |   |radio                       |
|       RR SPEAKER|blue - lt. blue     |   |radio                       |
Notes:
NOTE:  This vehicle is equipped with the pass-key III immobilizer.  Use DEI part number 555G or 555U to bypass during remote start mode.  *1 Lock and unlock use the same wire.  Lock requires a negative trigger with a 470 ohm resistor in-line.  Unlock is negative trigger. Must use relays.  *2 The BCM is located at the front of the center console under the radio.  *3 The liftgate glass pin switch is RED / black, also located in the pink plug at the BCM.
Thursday, March 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
