WIRE COLOR POLARITY LOCATION
Battery BROWN AND ORANGE (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PINS 12/33 OF 40 PIN PLUG
Ignition 1 YELLOW (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 35 OF 40 PIN PLUG
Starter 1 BLUE (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 15 OF 40 PIN PLUG
All Door Trigger BLACK/ WHITE (-) AT PLUG TOP OF FUSEBOX
Domelight Super BLUE
LF Latch RED (-) BECU PIN 14 OF A 16 PIN PLUG
RF Latch RED (-) BECU PIN 23 OF A 28 PIN PLUG
LR Latch GREEN (-) BECU PIN 11 OF A 28 PIN PLUG
RR Latch BLUE (-) BECU PIN 16 OF A 16 PIN PLUG
Trunk Trigger RED (-) BECU PIN 11 OF A 16 PIN PLUG
Hood Trigger WHITE/ BLUE (-) HOOD PIN SWITCH UNDER HOOD
Alarm Disarm ARMS WITH LOCKS
Alarm Arm DISARMS WITH UNLOCK
Parking Lights GREEN (+) AT THE BACK OF PARKING LIGHT UNDER HOOD
Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Ignition 2 LIGHT BLUE (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN34 OF 40 PIN PLUG
Accessory 1 GREEN (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 11 OF 40PIN PLUG
Starter 2 LIGHT BLUE (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 17 OF 40 PIN PLUG
Anti-Theft Type UNIVERSAL TRANSPONDER
Anti-Theft Descript THE KEY SENDS A RF SIGNAL TO THE BCM THROUGH A ANTENNA AROUND THE KEY CYLINDER
Key Sense BLUE/WHITE (-) IGNITION SWITCH HARNESS
Neutral Safety GREEN / WHITE (-) AT GEAR SELECTOR SWITCH
Tachometer WHITE (AC) PIN 9 AT THE DATA CONNECTOR
Speed Sense PURPLE (AC) ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 14 OF A 26 PIN PLUG
Brake Lights RED / BLACK (+) BRAKE PEDAL
Reverse Lights RED (+) ECU PIN13
Horn YELLOW (-) STEERING COLUMN HARNESS
