2007 Suzuki XL7 Alarm/Remote Start Wiring
jenny lopez
Posted: January 27, 2008 at 1:39 PM / IP Logged
hey i was wondering if anybody has any wire info for a 2007 suzuki xl7. the 2006 is not the same
KarTuneMan
Platinum - Posts: 7,056
Posted: January 27, 2008 at 7:23 PM / IP Logged
PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 Equipped with Passkey 3 (PK3) and Passlock system. Use an after-market bypass kit or refer to the provided security diagram for remote start instructions.
 12 VOLTS RED / white In Black plug on BCM in center console below radio   +
 IGNITION Pink In Green plug on BCM in center console below radio   +
 ACCESSORY Brown In Green plug on BCM in center console below radio   +
 STARTER Not required
 With proper bypass of the passive anti-theft system, the vehicle will crank automatically.
 TACH SIGNAL Use a fuel injector
 LOCK RED / black or Pink/black In Gray plug on BCM in center console below radio   -
 UNLOCK ORANGE / black In Gray plug on BCM in center console below radio   -
 DOORPIN SEE NOTES
 LF door is Tan/white (In Gray plug on BCM in center console below radio). Tan/white catches other 3 doors (In Pink plug on BCM in center console below radio)
 TRUNK PIN Pink/black In Pink plug on BCM in center console below radio   -
 BRAKESWITCH White In Brown plug on BCM in center console below radio   +
 PARKLIGHTS (-) BROWN / white In White plug on BCM in center console below radio   -
 HAND BRAKE ORANGE / black In Brown plug on BCM in center console below radio   -
 HORN Tan In Brown plug on BCM in center console below radio   -
 HEADLIGHTS Tan/white In Black plug on BCM in center console below radio   -
 REVERSE LIGHTS Lt.green In Pink plug on BCM in center console below radio   -
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
