2010 Mercury Milan Alarm/Remote Start Wiring
angelars
Copper - Posts: 176
Posted: April 26, 2009 at 12:42 PM / IP Logged
Would appreciate it if someone could please post the color codes for a 2010 Mercury Milan. The alarm/remote start is going to be a Viper 5901. Please keep in mind that a 2010 Milan is NOT the same as a 2009 Milan. If anyone has worked on a 2010 Fusion/Milan before I would appreciate it if you gave me any tips that you feel pertinent for working on this car.
Thanks guys.
chev104275
Gold - Posts: 1,424
Posted: April 27, 2009 at 6:23 PM / IP Logged
sorry looks like your gonna have to start testing      i looked at fords site and audiovox nobody has any info yet
angelars
Copper - Posts: 176
Posted: April 28, 2009 at 12:11 AM / IP Logged
I've got some time before the dealer gets the car in so if you see anything just post it. Thanks.
Also the 2010 Fusion is the same car, and they'd probably list the Fusion first because availability on it is a little better.
chev104275
Gold - Posts: 1,424
Posted: April 28, 2009 at 5:35 AM / IP Logged
im sure ill be getting one to do soon the dealer i work for has a bunch in stock so its matter of time   ok this is what i can find so far
12 volts is blue/red 20 amp
start is blue/white
ingition is WHITE/ orange
acc is violet/green
positive parking is violet/white
brake is violet/white
horn is blue/white
locks are yellow/violet for unlock
          blue/green for lock
the door pins and hood pin all rest on ground
make sure you test everything   good luck
angelars
Copper - Posts: 176
Posted: October 03, 2009 at 9:17 PM / IP Logged
Any update on the 2010 Milan/Fusion wiring color codes?
flobee4
Silver - Posts: 585
Posted: October 04, 2009 at 2:25 PM / IP Logged
Item     Wire Color     Polarity     Wire Location
12 Volts     blue/red (20A)     +     ignition switch, 7 pin plug, pin 4
Starter     blue/white     +     ignition switch, 7 pin plug, pin 7
Ignition     WHITE/ orange     +     ignition switch, 7 pin plug, pin 1 or SJB, black 52 pin plug (B), pin 45
Accessory     PURPLE / green     +     ignition switch, 7 pin plug, pin 6 or SJB, gray 14 pin plug (A), pin 3
Keysense     blue/gray     +     ignition switch, 7 pin plug, pin 5 or SJB, black 52 pin plug (B), pin 35
Data Bus     PURPLE / gray (TX), yellow/orange (RX)     data     PATS Transceiver, 4 pin plug, pins 3 and 4
The PATS (Passive Anti-Theft System) Transceiver is around the ignition key switch. The PATS ignition wire is blue/brown in pin 1 and the ground wire is BLACK/ purple in pin 2.
Can Bus High     gray/orange     data     data link conn, 16 pin plug, pin 3 or SJB, blk 52 pin plug (B), pin 37
The data link connector is under the driver dash.
Can Bus Low     PURPLE / orange     data     data link conn, 16 pin plug, pin 11 or SJB, blk 52 pin plug (B), pin 38
Power Lock     blue/green     -     driver kick or SJB, gray 26 pin plug (C), pin 17
Power Unlock     yellow/purple     -     driver kick or SJB, gray 26 pin plug (C), pin 4
Lock Motor     gray/brown     5 wire     driver kick or SJB, black 32 pin plug (D), pin 6
Driver Unlock Motor     blue/green     5 wire     driver kick or SJB, black 32 pin plug (D), pin 28
Passenger Unlock Motor     PURPLE / gray     5 wire     driver kick or SJB, black 32 pin plug (D), pin 27
Parking Lights (+)     PURPLE / white     +     driver kick or SJB, black 32 pin plug (D), pin 20
Headlight     blue/white     -     headlight switch or SJB, black 52 pin plug (B), pin 30
May need to interrupt the headlight switch ground wire when triggering this wire. It is BLACK/ purple at the headlight switch, 10 pin plug, pin 3.
AutoLights     PURPLE / green     -     headlight sw or SJB, black 52 pin plug (B), pin 50
Reverse Light     GREEN/ brown     +     driver kick, harness to rear
Dome Supervision     gray/purple     +     passenger kick or SJB, gray 14 pin plug (A), pin 9
The puddle lamps wire is purple (+) in the driver kick or SJB, gray 26 pin plug (C), pin 12.
Trunk/Hatch Pin     gray/orange      WHITE/ blue (-) at the luggage compartment light.
Trunk/Hatch Release     BROWN / yellow     -     release switch or SJB, gray 26 pin plug (C), pin 20
Trunk Release Motor     BROWN / blue     +     driver kick or SJB, black 32 pin plug (D), pin 31
Factory Alarm Arm     arms on lock with door open
Factory Alarm Disarm     factory remote only
Disarm No Unlock     PATS Transponder and ignition
Trunk Alarm Shunt     yellow/gray     -     driver kick or SJB, gray 26 pin plug (C), pin 22
Meter this wire while turning the key in the trunk key cylinder.
Tachometer     NOT blue     ac     any fuel injector
Clutch Pedal     BLACK/ green (in), blue/orange (out)     - N.O.     clutch switch, 2 pin plug, pins 2 and 1
Fuel Pump     PURPLE / green (gasoline) or gray / YELLOW (Hybrid)     +     driver kick, harness to rear
Rear Defroster     WHITE/ orange     - latched     HVAC Control Module, 26 pin plug (A), pin 12
Mirror Defroster     same as rear defroster
Left Front Heated Seat     WHITE/ blue     -     HVAC Control Module, 26 pin plug (A), pin 5
Right Front Heated Seat     gray / YELLOW     -     HVAC Control Module, 26 pin plug (A), pin 4
Speed Sense     PURPLE / orange (vehicles without rain sensor only)     8-Pulse     Wiper Module, 14 pin plug, pin 1 or PCM, top plug, pin 5
The Wiper Module is under the driver dash, behind the Smart Junction Box. The PCM (Powertrain Control Module) is in the engine compartment, behind the battery.
Brake Wire     PURPLE / white     +     brake switch or SJB, black 52 pin plug (B), pin 40
Parking Brake     WHITE/ purple     -     parking brake switch or SJB, gray 26 pin plug (C), pin 1
Horn Trigger     blue/white     -     horn switch or SJB, black 52 pin plug (B), pin 41
Wipers     blue/orange (L), PURPLE / orange (H)     -     wiper switch, 16 pin plug, pins 16 and 9
Left Front Window (Up/Down)     motor part of module
Right Front Window (Up/Down)     BROWN / yellow - GREEN/ orange     A     driver kick, door harness
Left Rear Window (Up/Down)     blue/orange - yellow     A     driver kick, door harness
Right Rear Window (Up/Down)     gray/purple - BROWN / green     A     driver kick, door harness
Sun Roof (Open/Close)     PURPLE / brown - yellow/orange     -     Sunroof Module, 14 pin plug, pins 5 and 6
The Sunroof Module is at the rear of the sunroof. When triggering these wires, you need to supply 12V to blue at the Sunroof Module, 14 pin plug, pin 2, to turn on the Sunroof Module.
The SJB (Smart Junction Box) is under the driver dash.
tommy...
Gold - Posts: 1,901
Posted: October 04, 2009 at 2:43 PM / IP Logged
BatteryBLUE/RED(+)IGNITION SWITCH HARNESS
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Ignition 1WHITE/ ORANGE(+)IGNITION SWITCH HARNESS
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Accessory 1VIOLET/GREEN(+)IGNITION SWITCH HARNESS
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Starter 1BLUE/WHITE(+)IGNITION SWITCH HARNESS
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Anti-Theft TypeFORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Key SenseBLUE/GRAY(+)IGNITION SWITCH HARNESS
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Crankshaft SensorGREEN/ BROWN(AC)AT PCM MODULE BETWEEN BATTERY AND FIREWALL UNDER HOOD
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Camshaft SensorBROWN / BLUE(AC)AT PCM MODULE BETWEEN BATTERY AND FIREWALL UNDER HOOD
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Parking LightsVIOLET/WHITE(-)DRIVERS KICK
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Brake LightsVIOLET/WHITE(+)DRIVERS KICK PANEL
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Reverse LightsGREEN/ BROWN(+)IN HARNESS IN DRIVERS DOOR SILL OR IN LEFT SIDE OF TRUNK
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.HornBLUE/WHITE(-)AT SMART JUNCTION BOX BEHIND DRIVERS SIDE OF DASH ABOVE KICKPANEL
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Rear DefrostWHITE/ ORANGE...VEHICLE IGNITION MUST BE POWERED TO REQUEST OPERATION. PULSE ONE TIME TO TURN ON, PULSE A SECOND TIME TO TURN OFF.2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Heated Driver SeatWHITE/ BLUE(-)IN HARNESS AT REAR OF HVAC CONTROLS...VEHICLE IGNITION MUST BE POWERED TO REQUEST OPERATION. PULSE ONE TIME TO TURN ON, PULSE A SECOND TIME TO TURN OFF.2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Heated Passngr SeatGRAY / YELLOW(-)IN HARNESS AT REAR OF HVAC CONTROLS...VEHICLE IGNITION MUST BE POWERED TO REQUEST OPERATION. PULSE ONE TIME TO TURN ON, PULSE A SECOND TIME TO TURN OFF.2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.
M.E.C.P & First-Class
tommy...
Gold - Posts: 1,901
Posted: October 04, 2009 at 2:49 PM / IP Logged
Power UnlockYELLOW/VIOLET(-)AT SMART JUNCTION BOX BEHIND DRIVERS SIDE OF DASH ABOVE KICKPANEL
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.PowerLockBLUE(-)AT SMART JUNCTION BOX BEHIND DRIVERS SIDE OF DASH ABOVE KICKPANEL
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Driver Mtr UnlockBLUE/GREEN(REV)AT MOTOR IN DOOR
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Driver Mtr LockGRAY/BROWN(REV)AT MOTOR IN DOOR
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Pas Mtr UnlockVIOLET/GRAY(REV)AT MOTOR IN DOOR
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Pas Mtr LockGRAY/BROWN(REV)AT MOTOR IN DOOR
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.LF Window UpBLUE/GRAY(REV)AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.LF Window DnYELLOW/VIOLET(REV)AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.RF Window UpBROWN / YELLOW(REV)AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.RF Window DnGREEN/ ORANGE(REV)AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.LR Window UpBLUE/ORANGE(REV)AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.LR Window DnYELLOW(REV)AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.RR Window UpGRAY/VIOLET(REV)AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.RR Window DnBROWN / GREEN(REV)AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Sunroof OpenVIOLET/BROWN(+)AT SUNROOF MOTOR MODULE IN ROOF
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Sunroof CloseYELLOW/ORANGE(+)AT SUNROOF MOTOR MODULE IN ROOF
Headlights-LoBLUE/WHITE(-)AT SMART JUNCTION BOX BEHIND DRIVERS SIDE OF DASH ABOVE KICKPANEL
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Headlights-HiWHITE/ ORANGE(-)AT SMART JUNCTION BOX BEHIND DRIVERS SIDE OF DASH ABOVE KICKPANEL
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.LF Pk Lt BulbVIOLET/WHITE(+)AT FRONT LEFT PARKING LIGHT
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.RF Pk Lt BulbVIOLET/WHITE(+)AT FRONT RIGHT PARKING LIGHT
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.LR Pk Lt BulbVIOLET/WHITE(+)AT REAR LEFT PARKING LIGHT
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.RR Pk Lt BulbVIOLET.WHITE(+)AT REAR RIGHT PARKING LIGHT
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.All Hazrd LightsBROWN / YELLOW(-)AT SMART JUNCTION BOX BEHIND DRIVERS SIDE OF DASH ABOVE KICKPANEL
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.LF Hazrd BulbBLUE/GREEN(+)AT FRONT LEFT DIRECTIONAL LIGHT
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.RF Hazrd BulbYELLOW/VIOLET(+)AT FRONT RIGHT DIRECTIONAL LIGHT
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.LR Hazrd BulbGRAY/BROWN(+)AT REAR LEFT DIRECTIONAL LIGHT
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.RR Hazrd BulbVIOLET/ORANGE(+)AT REAR RIGHT DIRECTIONAL LIGHT
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Wipers-LoGREEN/ VIOLET(-)IN HARNESS AT VEHICLE WIPER SWITCH
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Wipers-HiVIOLET/ORANGE(-)IN HARNESS AT VEHICLE WIPER SWITCH
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Parking BrakeWHITE/ VIOLET(-)AT SMART JUNCTION BOX BEHIND DRIVERS SIDE OF DASH ABOVE KICKPANEL...WIRE MAY ALSO BE FOUND AT BASE OF PARKING BRAKE HANDLE2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Trnk ReleaseBROWN / YELLOW(-)AT SMART JUNCTION BOX BEHIND DRIVERS SIDE OF DASH ABOVE KICKPANEL
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Seat Mem 1VIOLET/WHITE(-)AT MODULE INSIDE DRIVERS DOOR
2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.Seat Mem 2YELLOW(-)AT MODULE INSIDE DRIVERS DOOR
angelars
Copper - Posts: 176
Posted: October 04, 2009 at 4:44 PM / IP Logged
Wow... you guys are GREAT! THANKS! 2010 Mercury Milan Alarm/Remote Start Wiring -- posted image.
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
