2009 Honda Ridgeline Alarm/Remote Start Wiring
Welcome Guest :)
mgoup
Member -
Posted: July 09, 2009 at 9:54 AM / IP Logged
Looking for 2009 Honda ridgeline wiring diagram. Also, any tips/tricks about doing remote tailgate lock on this vehicle. thanks
KarTuneMan
Platinum -
Posted: July 27, 2009 at 11:45 PM / IP Logged
Here is a list for an 06.
The ONLY differance in an 06, and 09 is the brake wire.
The 09 is lt.blue.
richl68
Copper -
Posted: August 03, 2009 at 10:50 AM / IP Logged
12 Volts | white (50A) | + | ignition switch |
Second 12 Volts | N/A | | |
Starter | BLACK/ white | + | ignition switch |
Second Starter | N/A | | |
Ignition | BLACK / YELLOW | + | ignition switch |
Second Ignition | N/A | | |
| The MICU (Multiplex Integrated Control Unit) is part of the dash fuse box, in the driver kick. It has 2 plugs on the left side edge of the fuse box. |
Data Bus | RED / blu (immob data), blk/grn (ign), brn/yel (gnd) | data | Immobilizer Control Unit, green 7 pin plug, pins 2, 6, and 1 |
| The Immobilizer Control Unit is around the ignition key switch. The immobilizer light wire is blue/orange (-) at the Immobilizer Control Unit, green 7 pin plug, pin 5. |
| The MICU (Multiplex Integrated Control Unit) is part of the dash fuse box, in the driver kick. It has 2 plugs on the left side edge of the fuse box. Meter this wire while pressing the passenger door lock switch. |
richl68
Copper -
Posted: August 03, 2009 at 10:52 AM / IP Logged
Lock Motor | yellow/black | 5 wire | dash fuse box, lt. green 12 pin plug (K), pin 12 |
Driver Unlock Motor | YELLOW /GREEN | 5 wire | dash fuse box, lt. green 12 pin plug (K), pin 2 |
Passenger Unlock Motor | yellow | 5 wire | dash fuse box, white 45 pin plug (N), pin 9 |
Parking Lights (-) | blue | - | headlight switch, green 6 pin plug, pin 4 |
Parking Lights (+) | RED / black | + | dash fuse box, white 45 pin plug (N), pin 31 |
Hazards | GREEN/ red | + | MICU, green 30 pin plug, pin 28 |
Turn Signal (Left) | RED / blue | + | driver kick, harness to rear |
Turn Signal (Right) | brown | + | driver kick, harness to rear |
Headlight | blue/red | - | headlight switch, green 6 pin plug, pin 3 |
AutoLights | N/A | | |
Reverse Light | green | + | MICU, green 14 pin plug, pin 10 |
Left Front Door Trigger | green | - | driver kick, harness to rear |
| Can also use blue/red (-) at the interior light switch on the dash, gray 6 pin plug, pin 3, which will catch all the doors. |
richl68
Copper -
Dome Supervision | GREEN/ red | - | interior light switch on dash, gray 6 pin plug, pin 4 |
Trunk/Hatch Pin | blue / YELLOW (in-bed trunk), blue/orange (tailgate) | - | MICU, green 14 pin plug, pins 7 and 11 |
Rear Glass Pin | blue/orange (back power window) | - | driver kick, harness to rear |
Hood Pin | yellow/red to GREEN/ black | - | hood switch |
Trunk/Hatch Release | RED / blue (in-bed trunk) | - | MICU, green 14 pin plug, pin 12 |
| The MICU (Multiplex Integrated Control Unit) is part of the dash fuse box, in the driver kick. It has 2 plugs on the left side edge of the fuse box. Meter this wire while opening the in-bed trunk from the handle on the rear of the vehicle. |
Trunk Release Motor | yellow/blue (in-bed trunk) | 5 wire | right of parking brake, gray 14 pin plug, pin 14 |
Fuel Door Release | N/A | | |
Factory Alarm Arm | blue/white to WHITE/ red | - | power window master switch, white 23 pin plug, pin 8 |
| Meter this wire while turning the key in the driver door key cylinder. |
| The MICU (Multiplex Integrated Control Unit) is part of the dash fuse box, in the driver kick. It has 2 plugs on the left side edge of the fuse box. Meter this wire while turning the key in the in-bed trunk key cylinder. |
Tachometer | blue | ac | PCM, black 49 pin plug (A), pin 33 |
| The PCM (Powertrain Control Module) is in the engine compartment, on the passenger fender. Can also go to any fuel injector and use the wire that is not yellow/black. |
richl68
Copper -
Posted: August 03, 2009 at 10:53 AM / IP Logged
Fuel Pump | YELLOW /GREEN | + | driver kick, harness to rear |
Rear Defroster | GREEN/ black (heated windshield wiper area) | - latched | MICU, green 30 pin plug, pin 23 |
Mirror Defroster | orange | + latched | dash fuse box, lt. green 21 pin plug (J), pin 21 |
Left Front Heated Seat | gray/red | 5 wire | driver seat heater switch, blue 6 pin plug, pin 3 |
Right Front Heated Seat | green | 5 wire | passenger seat heater switch, green 6 pin plug, pin 3 |
Speed Sense | blue/white (some models only) | ac | PCM, black 49 pin plug (A), pin 30 |
| The PCM (Powertrain Control Module) is in the engine compartment, on the passenger fender. |
Brake Wire | lt. blue | + | brake switch or dash fuse box, white 45 pin plug (N), pin 26 |
Parking Brake | GREEN/ orange | - | parking brake switch |
Horn Trigger | GREEN/ YELLOW | - | left of brake switch, white 34 pin plug, pin 2 |
Wipers | GREEN / WHITE | - | left of brake switch, white 34 pin plug, pin 20 |
richl68
Copper -
Posted: August 03, 2009 at 10:55 AM / IP Logged
hope that helps a little...it wouldnt allow me to enter it all in one post.
Wednesday, April 24, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
