2009 Mitsubishi Outlander Alarm/Remote Start Wiring
malucyk
Copper - Posts: 56
Posted: October 03, 2009 at 5:27 AM / IP Logged
Can I please get a wiring diagram for a 2009 Mitsubishi Outlander.
Thank-you.
flobee4
Silver - Posts: 585
Posted: October 03, 2009 at 8:20 AM / IP Logged
Item     Wire Color     Polarity     Wire Location
12 Volts     white (80A), red (80A)     +     fuse box, black 2 pin plug, pins 1 and 2
Second 12 Volts     yellow (10A)     +     ignition switch, white 6 pin plug, pin 1
Starter     orange     +     ignition switch, white 6 pin plug, pin 5
Ignition     white     +     ignition switch, white 6 pin plug, pin 2
Accessory     lt. green     +     ignition switch, white 6 pin plug, pin 6
Keysense     RED / white     open     key switch, wht 12 pin plg, pin 3 or fuse box, wht 19 pin plg, pin 13
This wire rests at ground and goes to an open circuit when the key is inserted. On vehicles with KOS (Keyless Operating System), the knob push switch is green (+ resistor) at the key switch, white 12 pin plug, pin 4 or the KOS-ECU, white 40 pin plug, pin 8. The KOS-ECU is under the driver dash, to the right of the steering column.
Can Bus High     yellow (without KOS)     data     Wireless Control Module, white 12 pin plug, pin 11
The Wireless Control Module is around the ignition key switch. On vehicles with KOS (Keyless Operating System), this wire is gray at the KOS-ECU, white 40 pin plug, pin 1. The KOS-ECU is under the driver dash, to the right of the steering column.
Can Bus Low     lt. green (without KOS)     data     Wireless Control Module, white 12 pin plug, pin 10
The Wireless Control Module is around the ignition key switch. On vehicles with KOS (Keyless Operating System), this wire is purple at the KOS-ECU, white 40 pin plug, pin 2. The KOS-ECU is under the driver dash, to the right of the steering column.
Power Lock     WHITE/ black     -     driver kick, brown 24 pin plug, pin 2
Power Unlock     RED / yellow     -     driver kick, brown 24 pin plug, pin 3
Lock Motor     RED / green     5 wire     fuse box, white 19 pin plug, pin 6
Driver Unlock Motor     blue     5 wire     fuse box, white 19 pin plug, pin 2
Passenger Unlock Motor     green     5 wire     fuse box, white 19 pin plug, pin 5
Parking Lights (-)     (LIN data bus)
Parking Lights (+)     yellow (L), brown (R)     +     fuse box, white 20 pin plug, pins 10 and 13
Hazards     green     -     fuse box, top edge, white 24 pin plug, pin 19
Headlight     purple     -     fuse box, bottom edge, white 16 pin plug, pin 6
Reverse Light     white     +     fuse box, white 20 pin plug, pin 2
Left Front Door Trigger     yellow     -     fuse box, brown 16 pin plug, pin 16
Right Front Door Trigger     green     -     fuse box, brown 16 pin plug, pin 12
Left Rear Door Trigger     red     -     fuse box, brown 16 pin plug, pin 7
Right Rear Door Trigger     black     -     fuse box, brown 16 pin plug, pin 8
Dome Supervision     yellow     -     fuse box, white 6 pin plug, pin 5
Trunk/Hatch Pin     white     -     fuse box, brown 16 pin plug, pin 5
Hood Pin     RED / white     -     fuse box, bottom edge, white 16 pin plug, pin 12
Trunk/Hatch Release     brown (use trunk release motor if not present)     -     fuse box, brown 16 pin plug, pin 14
Meter this wire while opening the liftgate from the handle on the rear liftgate.
Trunk Release Motor     gray     5 wire     fuse box, white 20 pin plug, pin 1
Factory Alarm Arm     factory remote only
Factory Alarm Disarm     factory remote only
Disarm No Unlock     Transponder and ignition
Trunk Alarm Shunt     N/A
Tachometer     NOT RED / white (I-4) or blue (V6)     ac     any fuel injector
Fuel Pump     blue     +     fuse box, white 2 pin plug, pin 1
Rear Defroster     blue     - latched     fuse box, top edge, white 24 pin plug, pin 12
Mirror Defroster     same as rear defroster
Left Front Heated Seat          5 wire     left heated seat switch, 6 pin plug, pin 5
Right Front Heated Seat          5 wire     right heated seat switch, 6 pin plug, pin 5
Speed Sense     WHITE/ blue     ac     radio, white 20 pin plug, pin 11 or cluster, white 24 pin plug, pin 20
Brake Wire     red     +     brake switch or driver kick, harness to rear
Parking Brake     lt. green     -     parking brake switch or passenger kick, white 24 pin plug, pin 6
Also found at the instrument cluster, white 24 pin plug, pin 4.
Horn Trigger     green     -     horn switch or fuse box, white 19 pin plug, pin 19
malucyk
Copper - Posts: 56
Posted: October 03, 2009 at 1:18 PM / IP Logged
Thanks.
Does anyone recommend a particular bypass / data interface kit for the 2009 Mitsubishi Outlander?
Saturday, April 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
