viper 5901 on a 2008 toyota camry
snake212
Member - Posts: 14
Posted: January 25, 2010 at 3:50 AM / IP Logged
hello. i installed my car alarm and i wanted some help on a few things and i hope all my question will get answered.
-basically i want my car to chirp with the lock and unlock through the factory camry piezo speaker.
-i want only the signal lights to light up not the parking lights with lock and unlock.
-and also if it is possible to have my high beams light up when the alarm goes off.
Mike M2
Platinum - Posts: 2,652
Posted: January 25, 2010 at 6:30 AM / IP Logged
1    I'm sure it's possible, look for the piezo and apply power to it from the horn honk wire thru a relay.
2    Signals are the same as hazards, white negative at the switch. If you need turn signals, yellow and green at the fuse box, 12 pin plug, pin 9 and 12(may not be the same plug).
3    I'm sure finding the highbeam wire is simple, you know it's a negative at the light switch...
Mike M2
Tech Manager
CS Dealer Services
snake212
Member - Posts: 14
Posted: January 26, 2010 at 12:35 AM / IP Logged
thanks alot for the help. but from the alarm itself how would i make the high beams go off which wires would give that output?
Mike M2
Posted: January 26, 2010 at 6:25 AM / IP Logged
If you want them to flash you would use the parking light output, just be sure of polarity. How are your lights connected now? If they are negative you could just tap into them and diode isolate...
Mike M2
Tech Manager
CS Dealer Services
snake212
Member - Posts: 14
Posted: January 26, 2010 at 12:29 PM / IP Logged
But wouldn't that make the high beams flash when I lock and unlock the car?
kgerry
Platinum - Posts: 3,455
Posted: January 26, 2010 at 12:49 PM / IP Logged
tie it with a relay to your siren output....... but you'll need to program confirmation chirps off, or you'll have the same problem.......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
snake212
Member - Posts: 14
Posted: January 26, 2010 at 11:20 PM / IP Logged
but that will defeat the purpose of what i was doing. i wanted to have the factory chirp instead of the viper siren as unlock and lock confirmation.
kgerry
Posted: January 27, 2010 at 9:27 AM / IP Logged
i think the Idata module for that vehicle chirps thru the OE piezo......
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
snake212
Member - Posts: 14
Posted: January 28, 2010 at 1:28 AM / IP Logged
im not really familiar to the idatalink modules.
Mike M2
Posted: January 28, 2010 at 6:25 AM / IP Logged
I don't recall this but it may...
Mike M2
Tech Manager
CS Dealer Services
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
