2011 Ford F-250 Super Duty Diesel Alarm/RS/Stereo Wiring
locos4bass
Posted: January 10, 2011 at 7:47 AM / IP Logged
can any one help i am working on this 2011 f250 super duty diesel with the sync & mykeys system, i lates direcdttech i have is for for 2010 and some of the wire color codes and locations don't match up, it has 80-bit keys & i have a valet key for bypass. can't get it to r/s! tried putting key in ignition and jumping wires to simulate a r/s but nothing. any help or suggestions will be greatly apprecciated. thanks in advanced
monty_77
Copper - Posts: 491
Posted: January 10, 2011 at 11:49 AM / IP Logged
not sure if diesel is the same
2011 Ford F250      DirectWire 2.0 Vehicle Information
Item     Wire Color     Polarity     Wire Location
12 Volts     red (125A)     +     battery or BCM, black 1 pin plug (G), pin 1
     The BCM (Body Control Module) is the fuse box in the passenger kick.
Second 12 Volts     GREEN/ red or blue/red (15A)     +     ignition switch, 7 pin plug, pin 4
Starter     blue/white     +     ignition switch, 7 pin plug, pin 7
Second Starter     N/A
Ignition     WHITE/ orange     +     ignition switch, 7 pin plug, pin 1
Second Ignition     N/A
Third Ignition     N/A
Accessory     PURPLE / green     +     ignition switch, 7 pin plug, pin 6
Second Accessory     N/A
Third Accessory     N/A
Keysense     blue/gray     +     ignition switch, 7 pin plug, pin 5
Data Bus     yellow/orange (TX), PURPLE / gray (RX)     data     PATS Transceiver, black 4 pin plug, pins 3 and 4
     The PATS (Passive Anti-Theft System) Transceiver is around the ignition switch. The PATS ignition wire is PURPLE / orange in pin 1, and ground wire is BLACK/ gray or BLACK / YELLOW in pin 2.
Can Bus High     gray/orange (medium speed CAN)     data     data link connector, black 16 pin plug, pin 3
Can Bus Low     PURPLE / orange (medium speed CAN)     data     data link connector, black 16 pin plug, pin 11
Can Bus Sw     N/A
Power Lock     blue/green     -     driver kick or BCM, black 26 pin plug (C), pin 6
Power Unlock     yellow/purple     -     driver kick or BCM, black 26 pin plug (C), pin 8
Lock Motor     gray/brown     5 wire     driver kick or BCM, 32 pin plug (D), pin 26
Driver Unlock Motor     blue/green     5 wire     driver kick or BCM, 32 pin plug (D), pin 21
Passenger Unlock Motor     PURPLE / gray     5 wire     passenger kick or BCM, 32 pin plug (D), pin 31
Parking Lights (-)     yellow/orange     -     headlight switch, gray 10 pin plug, pin 2
     May need to interrupt the headlight switch ground wire when triggering this wire. It is BLACK/ gray or BLACK / YELLOW at the headlight switch, gray 10 pin plug, pin 3. See Tech Doc 1096 for wiring information.
Parking Lights (+)     yellow/blue     +     BCM, 10 pin plug (E), pin 6
Hazards     BROWN / yellow     -     BCM, black 52 pin plug (B), pin 32
Turn Signal (Left)     blue/green (F); gray/brown (R)     +     BCM, green 26 pin plug (F), pin 8; 32 pin plug (D), pin 12
Turn Signal (Right)     yellow/purple (F); PURPLE / orange (R)     +     BCM, green 26 pin plug (F), pin 7; 32 pin plug (D), pin 15
Headlight     yellow/blue     -     headlight switch, gray 10 pin plug, pin 7
AutoLights     PURPLE / green (interrupt to turn off autolights)     -     headlight switch, gray 10 pin plug, pin 4
Reverse Light     blue/white     +     BCM, 32 pin plug (D), pin 13
Left Front Door Trigger     GREEN/ purple     - N.C.     passenger kick or BCM, black 26 pin plug (C), pin 9
Right Front Door Trigger     white     - N.C.     passenger kick or BCM, black 26 pin plg (C), pin 5
Left Rear Door Trigger     green     - N.C.     passenger kick or BCM, blk 26 pin plug (C), pin 20
Right Rear Door Trigger     yellow     - N.C.     passenger kick or BCM, blk 26 pin plug (C), pin 21
Dome Supervision     gray/purple (dome lamp); purple (puddle lamp)     +     BCM, 12 pin plug (A), pin 1; black 26 pin plug (C), pin 1
Trunk/Hatch Pin     N/A
Rear Glass Pin     N/A
Hood Pin     blue/orange     - N.C.     BCM, green 26 pin plug (F), pin 2
Trunk/Hatch Release     N/A
Trunk Release Motor     N/A
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     arms on lock with door open
Factory Alarm Disarm     factory remote only
Disarm No Unlock     Transponder, ignition, and accessory
     See Tech Doc 1098 for wiring information.
Trunk Alarm Shunt     N/A
Tachometer     blue     ac     Customer Access Harness
     The Customer Access Harness is above the driver kick, taped to a wiring harness. On vehicles without the Customer Access Harness, go to any fuel injector and use the wire that is not blue (gasoline), or use the camshaft position sensor, which is WHITE/ green at the PCM, middle, black 98 pin plug, pin 32 (diesel). The PCM (Powertrain Control Module) is on the passenger side of the engine.
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     black (in), blue/orange or PURPLE / blue (out)     - N.O.     clutch switch, gray 6 pin plug, pins 2 and 1
Fuel Pump     yellow/purple (gasoline)     -     BCM, green 26 pin plug (F), pin 6
     The BCM (Body Control Module) is the fuse box in the passenger kick. On diesel models, use BROWN / white (+) at the Inertia Fuel Shutoff Switch above the passenger kick, gray 3 pin plug, pin 1.
Rear Defroster     WHITE/ orange     - latched     HVAC Module, gray 32 pin plug, pin 25
Mirror Defroster     same as rear defroster
Left Front Heated Seat     (CAN bus)
Right Front Heated Seat     (CAN bus)
Speed Sense     PURPLE / orange     ac     Customer Access Harness
Brake Wire     PURPLE / white     +     brake switch or BCM, black 52 pin plug (B), pin 28
Parking Brake     WHITE/ purple     -     Customer Access Harness
Horn Trigger     PURPLE / green     -     horn switch or BCM, black 52 pin plug (B), pin 33
Wipers     (LIN bus)
Left Front Window (Up/Down)     blue/gray - yellow/purple     A     master window switch, 8 pin plug, pins 5 and 1
Right Front Window (Up/Down)     BROWN / yellow - GREEN/ orange     A     driver kick, door harness
Left Rear Window (Up/Down)     blue/orange - yellow     A     driver kick, door harness
Right Rear Window (Up/Down)     gray/purple - BROWN / green     A     driver kick, door harness
     The power sliding rear window open/close wires are PURPLE / brown - yellow/orange (5 wire) at the overhead console switch, 12 pin plug, pins 4 and 9.
Sun Roof (Open/Close)     pur/brn - yel/org (function with ignition on only)     -     overhead console switch, 12 pin plug, pins 6 and 8
Sun Roof (Limit/Close)     N/A
Memory Seat 1     PURPLE / white     -     driver kick, door harness
Memory Seat 2     yellow     -     driver kick, door harness
Memory Seat 3     N/A
Radio 12V     gray/red     +     radio, gray 24 pin plug, pin 1
Radio Ground     BLACK/ blue or black     -     radio, gray 24 pin plug, pin 13
Radio Ignition     gray/blue (except navigation)     +     radio, gray 24 pin plug, pin 2
Radio Illumination     PURPLE / gray (dimmer)     +     radio, gray 24 pin plug, pin 3
Factory Amp Turn-on     PURPLE / red (sub amp); brown (audio amp)     +     radio, gray 8 pin plug, pin 4; gray 24 pin plug, pin 7
Power Antenna     N/A
Left Front Speaker (+/-)     white - WHITE/ brown     +,-     radio, gray 24 pin plug, pins 8 and 21
     If equipped, the audio amplifier is under the driver dash. On vehicles with amplifier, the speaker wires are white - WHITE/ brown at the audio amplifier, black 8 pin plug, pins 4 and 8.
Right Front Speaker (+/-)     WHITE/ purple - WHITE/ orange     +,-     radio, gray 24 pin plug, pins 11 and 12
     If equipped, the audio amplifier is under the driver dash. On vehicles with amplifier, the speaker wires are WHITE/ purple - WHITE/ orange at the audio amplifier, black 8 pin plug, pins 6 and 2.
Left Rear Speaker (+/-)     WHITE/ green - BROWN / yellow     +,-     radio, gray 24 pin plug, pins 9 and 22
     If equipped, the audio amplifier is under the driver dash. On vehicles with amplifier, the speaker wires are WHITE/ green - BROWN / yellow at the audio amplifier, black 8 pin plug, pins 7 and 3.
Right Rear Speaker (+/-)     BROWN / white - BROWN / blue     +,-     radio, gray 24 pin plug, pins 10 and 23
     If equipped, the audio amplifier is under the driver dash. On vehicles with amplifier, the speaker wires are BROWN / white - BROWN / blue at the audio amplifier, black 8 pin plug, pins 5 and 1.
Center Channel (+/-)     N/A
Subwoofer (+/-)     PURPLE / green - GREEN / WHITE     +,-     radio, gray 8 pin plug, pins 1 and 2
Aux. Audio Input Left (+/-)     blue - YELLOW /GREEN (without SYNC)     +,-     radio, gray 16 pin plug, pins 7 and 8
Aux. Audio Input Right (+/-)     blue/green - WHITE/ green (without SYNC)     +,-     radio, gray 16 pin plug, pins 6 and 14
RSE Video (+/-)     WHITE/ green - BROWN / purple (rear camera video)     +,-     radio, gray 10 pin plug, pins 1 and 6
RSE Audio Left (+/-)     grn/org - blu/brn or blu - gry/og (sat/SYNC audio)     +,-     radio, gray 16 pin plug, pins 1 and 2
RSE Audio Right (+/-)     pur/brn-yel/blu or pur/grn-brn/wh (sat/SYNC audio)     +,-     radio, gray 16 pin plug, pins 9 and 10
Satellite Radio 12 Volts     PURPLE / red     +     Satellite Receiver, black 12 pin plug, pin 9
     If equipped, the Satellite Receiver is under the driver dash.
Satellite Radio Ground     BLACK/ blue or black     -     Satellite Receiver, black 12 pin plug, pin 3
Satellite Radio Ignition     (CAN bus)
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     GREEN/ orange - blue/brown     +,-     Satellite Receiver, blk 12 pin plug, pins 5 and 11
Satellite Audio Right (+/-)     PURPLE / brown - yellow/blue     +,-     Satellite Receiver, blk 12 pin plug, pins 6 and 12
Item     Size     Depth     Location
Headunit     double DIN          center of dash
Left Front Speaker     6 x 8          left front door
Left Front Tweeter               left front door
Right Front Speaker     6 x 8          right front door
Right Front Tweeter               right front door
Left Rear Speaker     6 x 8          left rear door or left rear pillar
Left Rear Tweeter               left rear door
Right Rear Speaker     6 x 8          right rear door or right rear pillar
Right Rear Tweeter               right rear door
Center Channel     N/A
Subwoofer               under or behind rear seat
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner     (built into radio on some models)          under driver dash
Smart Starter Kill Relay
Relay Type:
Part #:
OE Relay Part #:
n/a
n/a
n/a
Notes:
n/a
Alternate Part Notes:
n/a
Interface Modules
SKU     Module Description     Upgradeable     Keys Required for Programming     Keys Required for Operation
© 2007 Directed Electronics. All Rights Reserved.
DirectWire and its vehicle information are for the sole use of authorized Directed Electronics personnel and it's participating dealers and distributors. The information contained on these pages may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited.
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
