only solutions i found,
xpresskit dball
fortin evo-all an evo-can
Item Wire Color Polarity Wire Location
12 Volts ORANGE / black (30A), gray (30A) + BCM, white 26 pin plug, pins 2 and 3
The BCM (Body Control Module) is under the driver dash.
Second 12 Volts RED / white (30A) + BCM, lt. blue 27 pin plug, pin 4
Starter yellow (2.0L), pur (2.4L) (for starter kill only) + starter or underhood fuse box, black 50 pin plug, pin 5
Second Starter PURPLE / gray +9.6K ohms ignition switch or BCM, lt. green 25 pin plug, pin 15
The BCM (Body Control Module) is under the driver dash. If interface module is not available, see Tech Doc 1605.
Ignition purple / YELLOW + ignition switch or BCM, lt. green 25 pin plug, pin 6
Second Ignition N/A
Third Ignition N/A
Accessory BROWN / yellow + ignition switch or BCM, lt. green 25 pin plug, pin 5
Second Accessory same as second starter +6.3K ohms
Third Accessory N/A
Keysense same as second starter
Data Bus PURPLE / gray (resistor code), WHITE/ black (5V ref) mux ignition switch or BCM, lt. green 25 pin plug, pins 15 and 22
Can Bus High dk. blue (high speed GMLAN) data data link connector, black 16 pin plug, pin 6
Can Bus Low white (high speed GMLAN) data data link connector, black 16 pin plug, pin 14
Can Bus Sw green (low speed GMLAN) data data link connector, black 16 pin plug, pin 1
Power Lock BROWN / yellow - BCM, gray 26 pin plug, pin 12
Power Unlock BROWN / white - BCM, gray 26 pin plug, pin 18
Lock Motor BROWN / yellow 5 wire BCM, pink 27 pin plug, pin 4
Driver Unlock Motor gray 5 wire BCM, pink 27 pin plug, pin 1
Passenger Unlock Motor WHITE/ red 5 wire BCM, pink 27 pin plug, pin 2
Parking Lights (-) lt. GREEN/ gray - BCM, white 26 pin plug, pin 22
Parking Lights (+) PURPLE / gray (L), gray/brown or RED / gray (R) + BCM, black 26 pin plug, pins 6 and 5
Hazards lt. GREEN / WHITE - BCM, lt. blue 27 pin plug, pin 26
Turn Signal (Left) dk. blue/white (F); dk. blue/white (R) + BCM, brown 26 pin plug, pins 2 and 1
Turn Signal (Right) GREEN/ purple (F); dk. blue/purple (R) + BCM, black 26 pin plug, pins 3 and 4
Headlight WHITE/ pur or white (also need parking lights (-)) - BCM, white 26 pin plug, pin 16
AutoLights GREEN/ brown (ground to turn off autolights) - BCM, white 26 pin plug, pin 11
Reverse Light GREEN / WHITE + BCM, gray 26 pin plug, pin 3
Left Front Door Trigger gray - driver window motor, black 7 pin plug, pin 6
Right Front Door Trigger gray - passenger window motor, black 7 pin plug, pin 6
Left Rear Door Trigger gray - left rear window switch, black 8 pin plug, pin 2
Right Rear Door Trigger gray - right rear window switch, black 8 pin plug, pin 2
Dome Supervision gray + BCM, lt. blue 27 pin plug, pin 5
Trunk/Hatch Pin PURPLE / gray - BCM, pink 27 pin plug, pin 5
Rear Glass Pin N/A
Hood Pin BROWN / green - BCM, black 26 pin plug, pin 24
Trunk/Hatch Release yellow/dk. blue (rear handle switch) - BCM, pink 27 pin plug, pin 15
Trunk Release Motor dk. blue / YELLOW or WHITE/ red 5 wire driver kick, black 102 pin plug, pin 83
Fuel Door Release unlocks along with driver door
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm factory remote only
Disarm No Unlock Passkey and ignition
Trunk Alarm Shunt N/A
Tachometer brown, dk. blue, dk. green, or lt. blue ac any fuel injector, black 2 pin plug, pin 1
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal N/A
Fuel Pump PURPLE / dk. blue + driver or passenger kick, harness to rear
Rear Defroster BROWN / purple + latched driver kick, black 102 pin plug, pin 19
Mirror Defroster same as rear defroster
Left Front Heated Seat (LIN bus)
Right Front Heated Seat (LIN bus)
Speed Sense gray or BROWN / dk. blue (some models only) ac driver kick, blk 102 pin plug, pin 32 or radio, gray 20 pin plug, pin 20
Brake Wire white + BCM, black 26 pin plug, pin 11
Parking Brake (high speed GMLAN)
Horn Trigger BROWN / white - BCM, brown 26 pin plug, pin 19
Wipers gray + BCM, black 26 pin plug, pin 16
Left Front Window (Up/Down) motor part of module
Right Front Window (Up/Down) motor part of module
Left Rear Window (Up/Down) blue/purple - yellow/dk. blue A left rear window switch, black 8 pin plug, pins 6 and 7
Right Rear Window (Up/Down) dk. blue/gray - lt. GREEN/ black A right rear window switch, black 8 pin plug, pins 6 and 7
Sun Roof (Open/Close) dk. blue/purple (open) (function with ign on only) - 85 ohms sunroof switch, black 4 pin plug, pin 4
Sun Roof (Limit/Close) (close) same as sun roof open - 600 ohms
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Radio 12V RED / lt. green + radio, black 44 pin plug, pin 44
Radio Ground black - radio, black 44 pin plug, pin 38
Radio Ignition (low speed GMLAN)
Radio Illumination (low speed GMLAN)
Factory Amp Turn-on white + radio, black 44 pin plug, pin 43
Power Antenna N/A
Left Front Speaker (+/-) dk. blue - BROWN / dk. blue +,- radio, black 44 pin plug, pins 40 and 32
If equipped, the amplifier is in the right side of the luggage compartment. On vehicles with amplifier, the speaker wires are dk. blue - BROWN / dk. blue at the amplifier, black 16 pin plug, pins 10 and 2.
Right Front Speaker (+/-) yellow - BLACK / YELLOW or yellow - ORANGE / black +,- radio, black 44 pin plug, pins 39 and 31
If equipped, the amplifier is in the right side of the luggage compartment. On vehicles with amplifier, the speaker wires are yellow - BLACK / YELLOW at the amplifier, black 16 pin plug, pins 11 and 3.
Left Rear Speaker (+/-) green - BLACK/ green or BLACK/ green - brown +,- radio, black 44 pin plug, pins 42 and 34
If equipped, the amplifier is in the right side of the luggage compartment. On vehicles with amplifier, the speaker wires are green - BLACK/ green at the amplifier, black 16 pin plug, pins 12 and 4.
Right Rear Speaker (+/-) white - BLACK/ dk. blue or BROWN / wht - blk/dk. blue +,- radio, black 44 pin plug, pins 41 and 33
If equipped, the amplifier is in the right side of the luggage compartment. On vehicles with amplifier, the speaker wires are white - BLACK/ dk. blue at the amplifier, black 16 pin plug, pins 13 and 5.
Center Channel (+/-) uses right front (+), left front (-)
If equipped, the amplifier is in the right side of the luggage compartment. On vehicles with amplifier, the speaker wires are yellow/white - BLACK/ dk. blue at the amplifier, black 16 pin plug, pins 14 and 6.
Subwoofer (+/-) BLACK/ brn - BLACK/ grn (L); GREEN/ pur - blk/gry (R) +,- amplifier, black 8 pin plug, pins 6 and 2; 7 and 3
Aux. Audio Input Left (+/-) PURPLE / white - BLACK/ dk. blue (without bluetooth) +,- radio, black 44 pin plug, pins 24 and 23
Aux. Audio Input Right (+/-) GREEN / WHITE - BLACK/ dk. blue (without bluetooth) +,- radio, black 44 pin plug, pins 10 and 23
RSE Video (+/-) N/A
RSE Audio Left (+/-) WHITE/ yellow - WHITE/ green (bluetooth/aux audio) +,- radio, black 44 pin plug, pins 24 and 23
RSE Audio Right (+/-) gray/white - WHITE/ green (bluetooth/aux audio) +,- radio, black 44 pin plug, pins 10 and 23
Satellite Radio 12 Volts N/A
Satellite Radio Ground N/A
Satellite Radio Ignition N/A
Satellite Radio Antenna N/A
Satellite Audio Left (+/-) N/A
Satellite Audio Right (+/-) N/A
Item Size Depth Location
Headunit irregular center of dash
Left Front Speaker left front door
Left Front Tweeter left front door
Right Front Speaker right front door
Right Front Tweeter right front door
Left Rear Speaker left rear door
Left Rear Tweeter N/A
Right Rear Speaker right rear door
Right Rear Tweeter N/A
Center Channel top center of dash
Subwoofer left and right rear deck
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
