2011 Chevrolet Traverse, Stereo/Remote Starter Wiring
gord1022
Posted: February 28, 2011 at 9:44 PM / IP Logged
I am looking for wiring diagram for a 2011 Chevrolet Traverse for remote starter.
Thanks Gord
shaggy12volt
Copper - Posts: 164
Posted: March 02, 2011 at 6:15 PM / IP Logged
here you go just did one today very easy
2011 chevy traverse
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     RED / black (x3) (50A each)     +     dash fuse box, black 84 pin plug, pins 5, 6, and 76
The dash fuse box is behind the glove box.
Second 12 Volts     RED / white (x4) (15A each)     +     BCM, black plug, pins 1, 2, 3, and 4
The BCM (Body Control Module) is under the driver dash, to the left of the steering column.
Starter     purple (for starter kill only)     +     starter or underhood fuse box, black 54 pin plug, pin 9
Second Starter     white     +9.6K ohms     ignition switch or BCM, lt. green plug, pin 2
The BCM (Body Control Module) is under the driver dash, to the left of the steering column. If interface module is not available, see Tech Doc 1605.
Ignition     pink     +     ignition switch or BCM, lt. green plug, pin 14
Second Ignition     N/A
Third Ignition     N/A
Accessory     brown     +     ignition switch or BCM, lt. green plug, pin 21
Second Accessory     same as second starter     +6.3K ohms
Third Accessory     N/A
Keysense     same as second starter
Data Bus     white (resistor code), WHITE/ black (5V reference)     mux     ignition switch or BCM, lt. green plug, pins 2 and 4
Can Bus High     tan/black (high speed GMLAN)     data     data link connector, black 16 pin plug, pin 6
Can Bus Low     tan (high speed GMLAN)     data     data link connector, black 16 pin plug, pin 14
Can Bus Sw     dk. green (low speed GMLAN)     data     data link conn, black 16 pin plug, pin 1 or BCM, lt. blue plug, pin 10
Power Lock     pink/black     -     BCM, gray plug, pin 12
The BCM (Body Control Module) is under the driver dash, to the left of the steering column. On vehicles with express up and down power windows, these wires are not present. To do door locks on these vehicles, you have to 5 wire the door lock motor wires in each front door, and trigger the rear doors power lock - unlock wires. The door lock motor wires are gray - tan at each front window switch, brown 16 pin plug, pins 7 and 8. The rear doors power lock - unlock wires are lt. green (+) - lt. blue (-) at the BCM, gray plug, pins 7 and 9.
Power Unlock     ORANGE / black (all doors), yellow (driver door)     -     BCM, gray plug, pins 11 and 6
Lock Motor     gray     5 wire     driver kick, door harness
On vehicles with express up and down power windows, use gray in the driver side rear door harness.
Driver Unlock Motor     tan     5 wire     driver kick, door harness
On vehicles with express up and down power windows, this wire is at the driver window switch, brown 16 pin plug, pin 8.
Passenger Unlock Motor     tan     5 wire     driver side rear door harness
Parking Lights (-)     BROWN / white     -     headlight switch or BCM, white plug, pin 8
Parking Lights (+)     purple (L), BROWN / white (R)     +     each kick, harness to rear
Hazards     tan     -     hazard switch or BCM, lt. green plug, pin 19
Turn Signal (Left)     lt. blue/white (F); yellow (R)     +     BCM, brown plug, pins 4 and 1
Turn Signal (Right)     dk. blue/white (F); dk. green (R)     +     BCM, black plug, pin 5; brown plug, pin 2
Headlight     white     -     headlight switch or BCM, white plug, pin 12
AutoLights     dk. green (ground to turn off autolights)     -     headlight switch or BCM, white plug, pin 17
Reverse Light     lt. green     +     BCM, pink plug, pin 2
Left Front Door Trigger     gray/black     -     BCM, pink plug, pin 10
The BCM (Body Control Module) is under the driver dash, to the left of the steering column. On vehicles with express up and down power windows, this wire is at the driver window switch, brown 16 pin plug, pin 13.
Right Front Door Trigger     tan/white     -     BCM, pink plug, pin 8
The BCM (Body Control Module) is under the driver dash, to the left of the steering column. On vehicles with express up and down power windows, this wire is at the passenger window switch, brown 16 pin plug, pin 13.
Left Rear Door Trigger     lt. blue/black     -     BCM, pink plug, pin 15
Right Rear Door Trigger     lt. GREEN/ black     -     BCM, pink plug, pin 14
Dome Supervision     gray/black     +     BCM, white plug, pin 5
Trunk/Hatch Pin     pink/black     -     BCM, pink plug, pin 12
The BCM (Body Control Module) is under the driver dash, to the left of the steering column. On vehicles with the power liftgate, this wire is at the LGM, black 16 pin plug, pin 5. The LGM (Liftgate Module) is in the left rear quarter panel.
Rear Glass Pin     N/A
Hood Pin     pink/black     -     hood switch or BCM, black plug, pin 17
Trunk/Hatch Release     gray (rear handle switch)     -     BCM, pink plug, pin 23
The BCM (Body Control Module) is under the driver dash, to the left of the steering column. On vehicles with the power liftgate, the open/close wire is dk. GREEN / WHITE at the switch in the dash or at the LGM, black 16 pin plug, pin 12. The LGM (Liftgate Module) is in the left rear quarter panel.
Trunk Release Motor     lt. blue     +     passenger kick, harness to rear
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     arms on lock with door open
Factory Alarm Disarm     factory remote only
Disarm No Unlock     Passkey and ignition
Trunk Alarm Shunt     N/A
Tachometer     tan     ac     any fuel injector, black 2 pin plug, pin 1
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     N/A
Fuel Pump     pink     +     underhood fuse box, black 54 pin plug, pin 18
Rear Defroster     white     + latched     HVAC Cntrl Module, blu 16 pin plg, pin 8 or blk 16 pin plg, pin 10
The HVAC Control Module is in the center of the dash, below the radio.
Mirror Defroster     same as rear defroster
On vehicles with express up and down power windows, use orange (+) at each front window switch, black 10 pin plug, pin 7.
Left Front Heated Seat     dk. blue (back and cushion)     -     driver heated seat switch, gray 10 pin plug, pin 4
Right Front Heated Seat     dk. blue (back and cushion)     -     passenger heated seat switch, black 10 pin plug, pin 4
Speed Sense     dk. GREEN / WHITE (some models only)     ac     EBCM, black 38 pin plug, pin 11 or radio, brown 16 pin plug, pin 5
The EBCM (Electronic Brake Control Module) is in the driver side rear corner of the engine compartment, near the brake master cylinder.
Brake Wire     lt. blue     +     BCM, brown plug, pin 5
Parking Brake     ORANGE / black     -     parking brake switch or BCM, brown plug, pin 16
Horn Trigger     tan     -     horn switch or BCM, brown plug, pin 18
Wipers     gray     +     BCM, brown plug, pin 20
Left Front Window (Up/Down)     dk. blue - brown     A     driver window switch, black 8 pin plug (X2), pins E and D
On vehicles with express up and down power windows, the driver window motor is part of a control module. Therefore, it is not possible to integrate an aftermarket window module.
Right Front Window (Up/Down)     dk. blue - brown     A     passenger window switch, black 8 pin plug, pins E and H
On vehicles with express up and down power windows, the passenger window motor is part of a control module. Therefore, it is not possible to integrate an aftermarket window module.
Left Rear Window (Up/Down)     dk. blue - brown     A     left rear window switch, black 8 pin plug, pins E and H
Right Rear Window (Up/Down)     dk. blue - brown     A     right rear window switch, black 8 pin plug, pins E and H
Sun Roof (Open/Close)     brown - orange (function with ignition on only)     -     sunroof switch, black 5 pin plug, pins D and E
Sun Roof (Limit/Close)     N/A
Memory Seat 1     orange     +2.26Kohms     driver window switch, lt. gray 14 pin plug, pin 5
Memory Seat 2     same as memory seat 1     +4.26Kohms
Memory Seat 3     N/A
Radio 12V     RED / white     +     radio, black 14 pin plug, pin 1
Radio Ground     BLACK/ white     -     radio, black 14 pin plug, pin 8
Radio Ignition     (low speed GMLAN)
Radio Illumination     PURPLE / white (dimmer)     +     radio, black 14 pin plug, pin 7
Factory Amp Turn-on     same as power antenna
Power Antenna     white     +     radio, black 14 pin plug, pin 6
Left Front Speaker (+/-)     tan - gray or tan/black - dk. green     +,-     radio, black 14 pin plug, pins 2 and 9
If equipped, the amplifier is under the driver dash, above the driver kick. On vehicles with amplfier, the speaker wires are tan - gray at the amplifier, lt. gray 8 pin plug, pins 5 and 1.
Right Front Speaker (+/-)     lt. green - dk. green or lt. GREEN / WHITE - lt. grn     +,-     radio, black 14 pin plug, pins 3 and 10
If equipped, the amplifier is under the driver dash, above the driver kick. On vehicles with amplfier, the speaker wires are lt. green - dk. green at the amplifier, black 16 pin plug (X2), pins 8 and 7.
Left Rear Speaker (+/-)     brown - yellow or BROWN / white - brown     +,-     radio, black 16 pin plug, pins 5 and 13
If equipped, the amplifier is under the driver dash, above the driver kick. On vehicles with amplfier, the speaker wires are brown - yellow at the amplifier, black 16 pin plug (X2), pins 15 and 16.
Right Rear Speaker (+/-)     dk. blue - lt. blue or dk. blue - tan     +,-     radio, black 16 pin plug, pins 6 and 14
If equipped, the amplifier is under the driver dash, above the driver kick. On vehicles with amplfier, the speaker wires are dk. blue - lt. blue at the amplifier, black 16 pin plug (X2), pins 2 and 1. The rear surround speaker wires are paralleled, and the wire colors are tan - white at the amplifier, black 16 pin plug (X2), pins 6 and 5.
Center Channel (+/-)     dk. blue - orange     +,-     radio, brown 16 pin plug, pins 3 and 11
If equipped, the amplifier is under the driver dash, above the driver kick. On vehicles with amplfier, the speaker wires are yellow - lt. blue at the amplifier, black 16 pin plug (X2), pins 4 and 3.
Subwoofer (+/-)     white - pink     +,-     radio, brown 16 pin plug, pins 4 and 12
If equipped, the amplifier is under the driver dash, above the driver kick. On vehicles with amplfier, the subwoofer wires are dk. blue/white - lt. GREEN/ black at the amplifier, lt. gray 8 pin plug, pins 7 and 3.
Aux. Audio Input Left (+/-)     yellow - (bare wire)     +,-     radio, lt. gray 16 pin plug, pins 1 and 9
The aux video input wires are purple - (bare wire) at the radio, lt. gray 16 pin plug, pins 8 and 16.
Aux. Audio Input Right (+/-)     white - (bare wire)     +,-     radio, lt. gray 16 pin plug, pins 2 and 9
RSE Video (+/-)     dk. green - WHITE/ black     +,-     radio, lt. gray 16 pin plug, pins 7 and 15
The rearview camera wires are pink - lt. blue at the radio, brown 16 pin plug, pins 6 and 7.
RSE Audio Left (+/-)     lt. blue - purple     +,-     radio, lt. gray 16 pin plug, pins 3 and 11
RSE Audio Right (+/-)     white - purple     +,-     radio, lt. gray 16 pin plug, pins 4 and 11
Satellite Radio 12 Volts     RED / white     +     Digital Radio Receiver, black 16 pin plug, pin 16
If equipped, the Digital Radio Receiver is in the left rear quarter panel.
Satellite Radio Ground     BLACK/ white     -     Digital Radio Receiver, black 16 pin plug, pin 9
Satellite Radio Ignition     (low speed GMLAN)
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     BROWN / white - tan/white     +,-     Digital Radio Receiver, blk 16 pin plug, pins 2, 1
Satellite Audio Right (+/-)     dk. GREEN / WHITE - gray     +,-     Digital Radio Receiver, blk 16 pin plug, pins 3, 4
Item     Size     Depth     Location
Headunit     double DIN          center of dash
Left Front Speaker     6.5          left front door
Left Front Tweeter               left front pillar
Right Front Speaker     6.5          right front door
Right Front Tweeter               right front pillar
Left Rear Speaker     6.5          left rear door
Left Rear Tweeter               left rear quarter panel
Right Rear Speaker     6.5          right rear door
Right Rear Tweeter               right rear quarter panel
Center Channel               top center of dash
Subwoofer               front of center console
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner               left rear quarter panel
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
gord1022
Posted: March 02, 2011 at 8:57 PM / IP Logged
THANKS I am having a problem with my bypass module. ADS-AL-CA I can't get it to do the programing of the key. It is wired in Idatalink mode. I have testes the passlock wiring and it has the proper voltages in all positions. Any suggestions
THX
shaggy12volt
Copper - Posts: 164
Posted: March 03, 2011 at 8:18 PM / IP Logged
what model remote start are you useing. are you doing type 2 or 3 on the ads al ca. are you doing wire to wire on it or d2d
The Shagmaster
gord1022
Posted: March 05, 2011 at 8:42 AM / IP Logged
I am installing autostart AS1475 with ads-al-ca by pass with type 2 install with the gm3 ring. The truck will remote start if you hold the gm3 module next to the ignition but if you plug it into the bypass and wrap the ring around the ignition it will not.  I have tried 3 different gm3 rings same problem.
shaggy12volt
Copper - Posts: 164
Posted: March 06, 2011 at 1:32 PM / IP Logged
pm me with you number and i will walk you throu it
The Shagmaster
gord1022
Posted: March 06, 2011 at 10:02 PM / IP Logged
Thanks, but I got it working turned out to be bad or used GM3 Ring. Tried a new one and works great. Thankyou for all your help
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
