2012 Subaru WRX STI Remote Start Wiring
smc0922
Member - Posts: 14
Posted: May 01, 2012 at 8:24 PM / IP Logged
As the title states, any data override info would also be greatly appreciated. Thanks!
-Shawn
AIM: Creegman9695
tommy...
Gold - Posts: 1,901
Posted: May 04, 2012 at 9:27 AM / IP Logged
2012 Subaru Impreza     DirectWire 2.0 Vehicle Information
Remote Start
Item     Wire Color     Polarity     Wire Location
12 Volts     white (common 50A)     +     ignition switch, white 8 pin plug, pin 4
Second 12 Volts     white (common 50A)     +     ignition switch, white 8 pin plug, pin 5
Starter     BLACK/ white     +     ignition switch, white 8 pin plug, pin 3
Second Starter     white     +     ignition switch, white 8 pin plug, pin 7
Ignition     green     +     ignition switch, white 8 pin plug, pin 1
Second Ignition     blue     +     ignition switch, white 8 pin plug, pin 6
Third Ignition     N/A
Accessory     yellow     +     ignition switch, white 8 pin plug, pin 2
Second Accessory     N/A
Third Accessory     N/A
Keysense     BLACK/ white     +     ignition key switch, white 2 pin plug, pin 2
Data Bus     red (keyless entry communication)     data     driver kick, white 24 pin plug, pin 1
Can Bus High     red     data     data link connector, black 16 pin plug, pin 6
Can Bus Low     blue     data     data link connector, black 16 pin plug pin 14
Can Bus Sw     N/A
Power Lock     lt. GREEN/ black     -     driver kick, white 28 pin plug, pin 15
Power Unlock     blue/black     -     driver kick, white 28 pin plug, pin 16
Lock Motor     RED / green     5 wire     driver kick, white 28 pin plug, pin 17
Driver Unlock Motor     lt. green     5 wire     driver kick, white 28 pin plug, pin 18
Parking Lights (-)     BLACK/ blue     -     headlight switch, white 20 pin plug, pin 18
Parking Lights (+)     BLACK/ white     +     dash fuse box, white 20 pin plug, pin 12
Hazards     green     -     left of steering column, white 17 pin plug, pin 10
Turn Signal (Left)     WHITE/ red     +     dash fuse box, white 20 pin plug, pin 20
Turn Signal (Right)     gray     +     dash fuse box, white 20 pin plug, pin 3
Headlight     blue/black     -     headlight switch, white 20 pin plug, pin 20
AutoLights     blue/orange (interrupt to turn off autolights)     -     headlight switch, white 20 pin plug, pin 19
Reverse Light     BROWN / yellow     +     passenger kick, white 20 pin plug, pin 4
Left Front Door Trigger     blue/orange to blue/white     -     driver kick, white 10 pin plug, pin 8
Right Front Door Trigger     blue/white to blue/orange     -     passenger kick, white 10 pin plug, pin 8
Left Rear Door Trigger     yellow/white     -     driver kick, white 10 pin plug, pin 9
Right Rear Door Trigger     WHITE/ red     -     passenger kick, white 10 pin plug, pin 9
Dome Supervision     GREEN/ YELLOW     -     left of steering column, white 12 pin plug, pin 9
Trunk/Hatch Pin     yellow/blue     -     passenger kick, white 10 pin plug, pin 10
Rear Glass Pin     N/A
Hood Pin     yellow/black (with remote start only)     -     Remote Start Module above brake pedal, white 4 pin plug, pin 4
Trunk/Hatch Release     grn/red (5dr rear handle sw) (4dr use trk rel mtr)     -     passenger kick, white 24 pin plug, pin 5
Trunk Release Motor     BLACK/ blue     5 wire     passenger kick, white 24 pin plug, pin 14
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     arms on lock with driver door open
Factory Alarm Disarm     see disarm no unlock
Disarm No Unlock     Transponder and ignition
Trunk Alarm Shunt     N/A
Tachometer     white, BLACK / YELLOW, BLACK/ red, or BLACK/ blue     ac     passenger rear of engine, black 54 pin plug, pin 54, 53, 52, or 51
Wait to Start     N/A
Neutral Safety     GREEN/ black (M/T)     -     Engine Control Mod behind glove box, white 35 pin plug, pin 35
Clutch Pedal     WHITE/ blue (input), lt. green (output)     + N.O.     clutch switch, white 2 pin plug, pins 1 and 2
Fuel Pump     RED / black     +     passenger kick, white 20 pin plug, pin 5
Rear Defroster     RED / green     + latched     passenger kick, white 20 pin plug, pin 13
Mirror Defroster     same as rear defroster
Left Front Heated Seat     RED / white (L), white (H)     5 wire     seat heater switch, white 8 pin plug, pins 3 and 8
Right Front Heated Seat     RED / blue (L), lt. green (H)     5 wire     seat heater switch, white 8 pin plug, pins 1 and 4
Speed Sense     pink/green (some models only)     ac     radio, white 20 pin plug, pin 19, or white 28 pin plug, pin 17
Brake Wire     brown     +     dash fuse box, white 20 pin plug, pin 15
Parking Brake     gray     -     driver kick, white 24 pin plug, pin 16
Horn Trigger     red     -     horn switch, white 14 pin plug, pin 9
Wipers     RED / blue (L), BLACK/ blue (H), GREEN/ black (ignit)     +     wiper switch, white 10 pin plug, pins 3, 4, and 2
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
M.E.C.P & First-Class
smc0922
Member - Posts: 14
Posted: May 05, 2012 at 10:07 AM / IP Logged
Thank you!
-Shawn
AIM: Creegman9695
tommy...
Gold - Posts: 1,901
Posted: May 05, 2012 at 10:13 AM / IP Logged
You're Welcome...
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
