2011 Hyundai Santa Fe DirectWire 2.0 Vehicle Information
Remote Start
Item Wire Color Polarity Wire Location
12 Volts red (40A) + ignition switch, black 6 pin plug, pin 5
Second 12 Volts pink (40A) + ignition switch, black 6 pin plug, pin 2
Starter green + ignition switch, black 6 pin plug, pin 1
Second Starter N/A
Ignition orange + ignition switch, black 6 pin plug, pin 6
Second Ignition N/A
Third Ignition N/A
Accessory blue + ignition switch, black 6 pin plug, pin 3
Second Accessory yellow + ignition switch, black 6 pin plug, pin 4
Third Accessory N/A
Keysense yellow + ignition key switch, white 6 pin plug, pin 3
Data Bus (only Canadian models have the immobilizer system)
Can Bus High yellow (B-CAN), blue (C-CAN) data data link connector, black 16 pin plug, pins 1 and 6
Can Bus Low black (B-CAN), orange (C-CAN) data data link connector, black 16 pin plug, pins 9 and 14
Can Bus Sw N/A
Power Lock blue/black - driver kick, brown 24 pin plug, pin 18
Power Unlock gray/black - driver kick, brown 24 pin plug, pin 19
To unlock the driver door only, use yellow/black (-) at the BCM, white 22 pin plug, pin 13. The BCM (Body Control Module) is under the driver dash, behind the dash fuse box.
Lock Motor orange 5 wire dash fuse box, gray 18 pin plug (D), pin 18
Driver Unlock Motor blue 5 wire driver kick, brown 24 pin plug, pin 1
Parking Lights (-) blue/orange - headlight switch, white 18 pin plug, pin 14
Parking Lights (+) green (L), yellow (R) + dash fuse box, gray 18 pin plug (D), pins 3 and 4
Hazards gray - BCM, white 22 pin plug, pin 7
Turn Signal (Left) white + dash fuse box, gray 18 pin plug (D), pin 11
Turn Signal (Right) pink + dash fuse box, gray 18 pin plug (D), pin 10
Headlight green (functions with ignition on only) - headlight switch, white 18 pin plug, pin 15
AutoLights GREEN/ black (interrupt to turn off autolights) - headlight switch, white 18 pin plug, pin 16
Reverse Light blue + passenger kick, red 20 pin plug, pin 2
Left Front Door Trigger orange - driver kick, brown 24 pin plug, pin 12
Right Front Door Trigger same as left front door trigger
Left Rear Door Trigger same as left front door trigger
Right Rear Door Trigger same as left front door trigger
Dome Supervision brown - dash fuse box, red 16 pin plug (B), pin 1
Trunk/Hatch Pin yellow/black - driver kick, brown 24 pin plug, pin 15
Rear Glass Pin N/A
Hood Pin RED / black - driver kick, green 24 pin plug, pin 4
Trunk/Hatch Release locks/unlocks along with doors
Trunk Release Motor N/A
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm BROWN / org (key lock), gray (lock/unlock detection) - and open driver kick, brown 24 pin plug, pins 5 and 4
See Tech Doc 1300 for wiring information.
Factory Alarm Disarm pink (key unlock), gray (lock/unlock detection) both - driver kick, brown 24 pin plug, pins 6 and 4
Disarm No Unlock see factory alarm disarm
Trunk Alarm Shunt N/A
Tachometer NOT orange ac any fuel injector
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal black (input), WHITE/ orange (output) - N.O. clutch switch, white 2 pin plug, pins 1 and 2
Fuel Pump blue + passenger kick, red 20 pin plug, pin 17
Rear Defroster gray - latched driver kick, green 24 pin plug, pin 15
Mirror Defroster same as rear defroster
Left Front Heated Seat GREEN/ orange - driver kick, brown 24 pin plug, pin 8
Right Front Heated Seat GREEN/ black - driver kick, brown 24 pin plug, pin 7
Speed Sense brown 4-Pulse data link conn, blk 16 pin plug, pin 3 or radio, gry 8 pin plug, pin 1
Brake Wire GREEN/ black (2.4L), gray (3.5L) + brake switch, white 4 pin plug, pin 1
Parking Brake gray/orange - driver kick, blue 22 pin plug, pin 12
Horn Trigger gray/black - driver kick, green 24 pin plug, pin 20
Wipers green (low), pink (high), yellow (ignition) + wiper switch, black 14 pin plug, pins 2, 1, and 5
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
M.E.C.P & First-Class
