monoshot 555 or multiple relay?
axel87
Member - Posts: 13
Posted: August 26, 2012 at 12:49 PM / IP Logged
I am working on a project for a 1100 vstar. The bike doesnt have a 4 way flasher.
I am trying to decide if I can use the Latched On/Off Output Using a Single Momentary Pulse circuit they have on this site. Or if i should use a 555 timer circuit.
I do not want to put another switch on the handlebars.
The trigger I was thinking would be the horn when the turn signals are on. Or a left/off/left/off sequence.
I tried looking on the forum for similar project, but i didnt see anything that looked exactly right.
Appreciate any help! Thank you
axel87
Member - Posts: 13
Posted: August 26, 2012 at 12:51 PM / IP Logged
Here is a copy of my turn signal switch.
http://postimage.org/image/cp51jz3n3/
And this is the 555 timer circuit I was debating on trying.
http://andreapg.altervista.org/on-off.jpg
Thanks again in advance.
enoxos
Member - Posts: 34
Posted: June 21, 2013 at 5:54 PM / IP Logged
did you ever build this circuit? I am very interested.
axel87
Member - Posts: 13
Posted: June 30, 2013 at 1:48 AM / IP Logged
Currently working on this still.
I am going to use a PICAXE to accomplish the hazard flash.
Reason its taking so long is I am going to add a bunch of other features: LCD Display for Tach/volt meter, leds and control, Ipod control.
But the Hazard circuit will be quite simple.
I can post the code and circuit if needed when all is done.
Remind me if I forget ;)
Tuesday, October 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
