how to wire a 12v light to a led circut
1redvert
Member - Posts: 15
Posted: September 18, 2012 at 10:47 AM / IP Logged Link to Post Post Reply Quote 1redvert
or would this reed relay be better?
http://www./itm/0-5-Amp-SPST-Reed-Relay-at-12VDC-2160388-/150888992653?pt=LH_DefaultDomain_0&hash=item2321af4f8d
KPierson
Platinum - Posts: 3,527
Posted: September 18, 2012 at 10:54 AM / IP Logged Link to Post Post Reply Quote KPierson
If it is brown, red, black, black then you are looking at an R of 120 ohms. I = 5/120 = ~41mA.
However, like I mentioned before, and a quick Google search verified, the actual pin can only supply 25mA of current.
I couldn't get the link to the SSR to load. I, personally, wouldn't use an SSR as you are trying to power a low current device. SSRs are known to have a small leakage current that may cause the light to light dimly when not in use.
My recommendation would be to use a 5vdc reed relay. It has a coil that will draw minimal current and has a set of contacts that will be perfect to power your 25mA device.
http://www.radioshack.com/product/index.jsp?productid=2062478
Kevin Pierson
KPierson
Posted: September 18, 2012 at 10:58 AM / IP Logged Link to Post Post Reply Quote KPierson
You need a 5vdc reed relay, but that is very, very close.
Kevin Pierson
1redvert
Member - Posts: 15
Posted: September 18, 2012 at 11:57 AM / IP Logged Link to Post Post Reply Quote 1redvert
sweeet that's what I've been looking for is the right one and they have that one at my local radio shack down the street. (i live in the mountains and they never have anything i need)
ok now all i have to do is replace the led with the coil of the reed switch and wire the contacts of the reed to the led strip right.
I really like electronics and would love to take a class to expand my very limited knowledge...thanks for all the help
1redvert
Member - Posts: 15
Posted: September 18, 2012 at 7:03 PM / IP Logged Link to Post Post Reply Quote 1redvert
the reed relay i got says 250 ohms do you think i will need to change or remove the resistor that is before the led? or just soldier it in and not worry about it?
KPierson
Posted: September 18, 2012 at 7:08 PM / IP Logged Link to Post Post Reply Quote KPierson
I'm assuming they are talking about the coil. That will give you a 20mA draw. That should be fine for your application, although it is approaching the upper limit of what the pin can safely supply. However, since it is a shift light and the actual "ON" time should be very low, it should be OK.
The resistor is in line to limit current to prevent damage to the pin. When you add the resistance of the new coil in series to the existing coil it will limit current too much. You will need to remove (or bypass) the resistor on the board for that relay to work.
Kevin Pierson
1redvert
Member - Posts: 15
Posted: September 18, 2012 at 8:45 PM / IP Logged Link to Post Post Reply Quote 1redvert
great thanks, thats what i was thinking as i was looking at it. I am just learning about resistors and leds because i wanted to put custom green leds in my Porsche 911 gauges. i will try and work on it later tonight and get it installed by this weekend. thanks again for all your help.
agemax
Member - Posts: 46
Posted: October 09, 2016 at 12:06 PM / IP Logged Link to Post Post Reply Quote agemax
I was trawling the internet for help and i came across this thread, so i thought i would resurect it. I have just bought the same style shift light although a much updated version looking at the difference in the circuit boards....
how to wire a 12v light to a led circut - Page 2 -- posted image.
my (probably stupid)questions are, how does this shift light work? you adjust the knob to what rpm you want the light to come on, but how does it know??
secondly, the output to power the LED (has been cut off in the pic, l/h side) is only 5v. is it possible to increase the output to 12v to power an external led that i already have, or will i just need to replace mine with 5v led's?
TIA
KPierson
Posted: November 07, 2016 at 11:52 PM / IP Logged Link to Post Post Reply Quote KPierson
Most modern shift lights measure frequency of either an injector or coil (or other pulsing signal that changes in a linear fashion with RPM). The pot is most likely creating a 0-5vdc signal that is going back to a processor that is converting the analog voltage to a digital representation and then comparing that value to the measured frequency. If the frequency value is lower than the voltage setpoint the light comes on.
You could add a transistor inline with the output to drive your 12v LED.
Kevin Pierson
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
