Ah - but that boot battery MUST - or should I say shall (with its Aussie legal meaning) - have its own fuse.
And BTW - EACH battery is to have a fuse or fuses. Many with dual or multi-batteries only have one, and one is required AT EACH battery (except when physical protection applies, but more on that later...)
As to within 12", there is no such
specific rule per se, but 12" and 18" are two distances often quoted.
The real rule is essentially "
fuse it before (where) a short could occur" but bear in mind other rules or recommendations like not in the gassing zone of a battery or other explosive atmosphere, and the classic - make sure your protection (ie, fusing) does not itself cause a hazard!
Alas I've written this sort of rambling treatise before, but maybe another "top down" but brief paraphrasing to help clarify:
All electrical power sources should employ (downstream) protection (for safety reasons). [Should means must or shall.]
Protection can be physical or electrical.
Electrical protection means fuses or circuit breakers etc.
Physical means adequate physical protection like insulation or ducting AND maintenance procedures. EG - telco's with huge 48V (& maybe 24V & 12V) battery systems using un-fused copper bus bars, sometimes insulated, with metal ladders banned and warnings like "
do not short your screwdriver or spanner or crowbar or equipment cubicle across these un-fused bussbars!.
Battery to starter-motor cabling is another common example of an un-fused physically protected cable/distribution.
The protection is to protect
downstream distribution until the next protection.
That means that a fuse protects its downstream cable. EG - a 100A fuse from the battery for its 100A or higher rated cable until it gets to a downstream (100A rated input) distribution block or fusebox which may then have smaller fuses to protect its emanating cables.
Note the basic requirement in the last - an upstream fuse must be rated equal to or less than the lowest rated cable or relay or connector etc it feeds [until another (smaller) fuse takes over].
Damn - a part ramble. But I wanted to include some examples or clarification. I haven't included all the issues and considerations.
I wrote the above because I think of common examples where people follow the "fuse rule" yet IMO create a bigger hazard.
EG - alternator to battery cables were once NOT fused. They relied instead on physical protection. (Newer vehicles generally all include fuses.)
One the12volt poster upgraded his alternator to battery or fusebox cable with a BIG cable. But instead of having a relatively short cable from the alternator to the target (battery or fusebox), he included a fuse and thereby probably trebles his cable length.
Not that the trebled length was an issue, but it's where the cable ran to include the fuse. IMO there was far greater chance of that cable shorting before the fuse than what the direct
alternator to target cable would have had. Ergo, IMO by including the
electrical protection he created a hazard that was greater than NOT including it.
Note that my reply has only considered
distribution protection. It does not include equipment protection, but that is usually in the device else is the last fuse before the device (but can also be ANY upstream fuse). And some equipment can't be protected anyway.
Re alternator & starter wiring, sure, anytime.
If not too late, I recommend a "2 wire all-in-one" alternator - ie, an alternator with internal voltage regulator and with an S or
Sense terminal as well as the usual L or charge-Lamp terminal (often called D+ in single-wire alternators, but they have no external Sensing).
The external sensing means that the battery can be anywhere and have whatever distribution voltage drops and the alternator correctly regulates
its voltage. Vehicle alternator voltages are geared to providing the voltage that the battery requires - ie, up to 14.4V.
A D+ alternator outputting its max of say 14.2V that has a 0.5V drop to the battery means the battery is only getting max of 13.7V which meas premature failure of the battery.
Mind you, a 14.4V boot battery with a 2V drop from the alternator means 16.4V at the alternator and hence maybe other car electrics which might fry them, hence good earths/grounds and distribution is essential (ie, the big-3 or 4). However many S-type alternators have an inbuilt maximum output of around 15.5V which all car electrics should handle.
FYI - except for a 6-month (disastrous?) foray into another common alternator, I have only used Japanese alternators and hence have not had the same over- or under-charging voltage issues that others have had, nor the problem of blowing main diodes on flat batteries or after jump starts.
And BTW I fitted a reduction starter motor which not only uses less current (140A as opposed to 240A), but also crankes to a far lesser voltage (eg, 5V versus maybe 8V). That was one of my better $45 wrecker/salvage/recycler investments!
Brief? Brief indeed!
Another short non-rambling reply brought to you by yours unbelievably.
