2007 Ford F150 FX4/Lariat Alarm/Stereo Wiring
roger8wilco
Posted: November 15, 2012 at 9:43 PM / IP Logged
Installing a Viper 5204 Remote Start/Alarm System. Looking for a complete wire breakdown. The one on the12volt doesn't show all the wires to hook it up. Thanks.
lurch228
Silver - Posts: 1,338
Posted: November 16, 2012 at 12:30 AM / IP Logged
If you have a Extended cab or 4 door the wiring can be different!
2007 FORD F150 2DR TRUCK WITH 5.4L ENGINE
Security
WIRE COLOR POLARITY LOCATION
Battery LIGHT GREEN/ VIOLET (+) IGNITION SWITCH HARNESS
Ignition 1 BLUE/LIGHT GREEN (+) IGNITION SWITCH HARNESS
Starter 1 RED / LIGHT BLUE (+) IGNITION SWITCH HARNESS
All Door Trigger BLACK/ LIGHT BLUE (+) AT VEHICLE LIGHT SWITCH HARNESS
Domelight Super BLACK/ BLUE (+) AT VEHICLE LIGHT SWITCH HARNESS
LF Latch BLACK / YELLOW (-) AT BCM MODULE BEHIND TRIM IN REAR OF CAB ON DRIVERS SIDE
   PIN #4
RF Latch BLACK/ PINK (-) AT BCM MODULE BEHIND TRIM IN REAR OF CAB ON DRIVERS SIDE
   PIN #5
Parking Lights BROWN (+) AT VEHICLE LIGHT SWITCH HARNESS
Convenience
Headlights-Lo RED / YELLOW (+) AT VEHICLE LIGHT SWITCH HARNESS
Wipers-Lo BLACK (-) AT VEHICLE WIPER CONTROL SWITCH
Parking Brake LIGHT GREEN/ RED (-) AT SWITCH HARNESS ABOVE PARKING BRAKE PEDAL
Seat Mem 1 BROWN / LIGHT GREEN (-) AT SEAT MEMORY SWITCH
Seat Mem 2 BLACK/ ORANGE (-) AT SEAT MEMORY SWITCH
Remote Start
Accessory 1 BLACK/ LIGHT GREEN (+) IGNITION SWITCH HARNESS
Anti-Theft Type FORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLACK/ PINK (+) IGNITION SWITCH HARNESS
Neutral Safety PINK/LIGHT GREEN (-) PCM MODULE ON PASSENGER SIDE FIREWALL
   PIN #46
Tachometer TAN (AC) PCM MODULE ON PASSENGER SIDE FIREWALL
   PIN #52
Crankshaft Sensor GRAY (-) AT PCM MODULE ON PASSENGER SIDE OF FIREWALL NEAR BATTERY
   PIN #46
Camshaft Sensor DARK GREEN (-) AT PCM MODULE ON PASSENGER SIDE OF FIREWALL NEAR BATTERY
   PIN #45
Speed Sense GRAY/BLACK (-) PCM MODULE ON PASSENGER SIDE FIREWALL
   PIN #63
Brake Lights LIGHT GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights DARK GREEN/ YELLOW (+) AT CENTRAL JUNCTION BOX IN PASSENGER KICKPANEL
Horn DARK BLUE (-) IN HARNESS AT STEERING COLUMN
Anti Theft RX GRAY/ORANGE
Anti Theft TX WHITE/ LIGHT GREEN
Rear Defrost ORANGE / YELLOW (-) AT CENTRAL JUNCTION BOX IN PASSENGER KICKPANEL
   THIS WIRE WILL ALSO CONTROL HEATED MIRROR IF EQUIPPED
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock PINK/GREEN (-) AT BCM MODULE BEHIND TRIM IN REAR OF CAB ON DRIVERS SIDE
   PIN #1
PowerLock PINK / YELLOW (-) AT BCM MODULE BEHIND TRIM IN REAR OF CAB ON DRIVERS SIDE
   PIN #9
Driver Mtr Unlock RED / ORANGE (AC) AT MOTOR IN DOOR
Driver Mtr Lock PINK/BLACK (AC) AT MOTOR IN DOOR
Pas Mtr Unlock PINK/ORANGE (AC) AT MOTOR IN DOOR
Pas Mtr Lock PINK/BLACK (AC) AT MOTOR IN DOOR
LF Window Up TAN/LIGHT BLUE (REV) AT DRIVER WINDOW CONTROL SWITCH
LF Window Dn WHITE/ BLACK (REV) AT DRIVER WINDOW CONTROL SWITCH
RF Window Up TAN/LIGHT BLUE (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
RF Window Dn WHITE/ YELLOW (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
lurch228
Posted: November 16, 2012 at 12:51 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / F150 / 2007 / Remote Start
[PRINT THIS PAGE]
12volts lt. GREEN/ purple (20A) + ignition harness
Starter RED / lt. blue + ignition harness
Second Starter N/A
Ignition dk. blue/lt. green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ lt. green + ignition harness
Second Accessory N/A
Keysense BLACK/ pink + ignition harness
Power Lock pink / YELLOW - DKP or BCM, green plug, pin 9
Notes: The BCM (Body Control Module) is on the driver side rear cabin wall.
Power Unlock pink/lt. green - DKP or BCM, green plug, pin 1
Lock Motor pink/black 5wi DKP or BCM, blue plug, pin 2
Unlock Motor RED / orange 5wi DKP or BCM, blue plug, pin 5
Parking Lights+ brown + switch or BCM, blue plug, pin 6
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) + turn signal switch
Turn Signal(R) wht/lt blu (F), org/lt blu (R) + turn signal switch
Reverse Light BLACK/ pink + DKP, gray plug, pin 13
Door Trigger BLACK/ yel (L), BLACK/ pink (R) - DKP, gray plug, pins 22, 23
Notes: The wiring above is for vehicles without keyless entry. Vehicles with keyless entry, the door trigger wires are found at the BCM, green plug. The LF door trigger is BLACK / YELLOW in pin 4. The RF door trigger is BLACK/ pink in pin 5. The LR door trigger is BLACK/ lt. blue in pin 12. The RR door trigger is BLACK/ white in pin 13. Use all wires and diode isolate each.
Dome Supervision BLACK/ lt. blue + DKP, gray plug, pin 6
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Car Tachometer Wire (-): Blue
Car Tachometer Wire Location: At Harness Next to the Brake Pedal
Tachometer NOT RED / lt. green or red ac any ignition coil or fuel injector
Otherwise any odd colored wire at fuel injector (NOT RED)
Wait to start N/A
Brake Wire lt. green + brake pedal switch
Parking Brake lt. GREEN/ red - parking brake switch
Horn Trigger dk. blue - switch or BCM, blue plug, pin 12
Memory Seat 1 BROWN / lt. green - memory seat switch on seat
Memory Seat 2 BLACK/ orange - memory seat switch on seat
Memory Seat 3 N/A -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
SecuriLock
Part #: XK04
Alternate Part1 #: 1100F/1100X
Alternate Part2 #: 556SW
Alternate Part3 #: 556UW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes: Standard on all models. When using the 1100X, a software change to 1100FM is needed.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
