gps drawing power from battery buzzer?
cwodavids
Member - Posts: 9
Posted: July 11, 2013 at 2:07 PM / IP Logged
Hi all,
Firstly, i have very little electronics experience but do possess a brand new £35 multimeter :-)
Secondly, I fitted a Tomtom Rider GPS to my Yamaha Fazer 600 (60 plate) with a switch (that has a light) half way along the power cable to ensure I don't drain the battery when I am not using it. I would like to fit either a buzzer that activates when the bike isnt running or open to ideas from others as to how I can stop my battery running flat when I forget to turn the switch off.
Any help greatly appreciated in the form of ideas, advice, links or diagrams.
Dave
Platinum - Posts: 13,728
Posted: July 11, 2013 at 4:06 PM / IP Logged
You can catch a wire at the ignition switch, or either the headlamp or the tail lamp that is hot only when the key is in the on position.
cwodavids
Member - Posts: 9
Posted: July 11, 2013 at 4:15 PM / IP Logged
That will mean the buzzer is on constantly, no?! Unless you mean the power connection directly to the GPS?
I'm assuming your mean option 2, if that is the case, do I just connect both wires for the GPS power to the ignition wire?
I know I am sounding pretty stupid, but I am no I promise, lol.
Posted: July 11, 2013 at 5:29 PM / IP Logged
How many wires total on the GPS? And what colors are the wires?
cwodavids
Member - Posts: 9
Posted: July 12, 2013 at 2:09 AM / IP Logged
2 wires, red and black, these are attached to the same colour terminals on the battery.
Posted: July 12, 2013 at 8:42 AM / IP Logged
Leave the black where it is and move the red one to the taillight wire. The harness with the taillight wire should pass right by the battery.
cwodavids
Member - Posts: 9
Posted: July 12, 2013 at 1:37 PM / IP Logged
Gggggrrrrrr i managed to get it all wired up correctly and now the small transformer that converts the battery power input to 5v 2 Amp has decided to stop working. I checked with the multimeter, the 12v is going in, nothing out the other side, looks like the PCB is not working now... Any ideas?
Dave
P.s. thank you so much for the help so far.
Posted: July 12, 2013 at 5:06 PM / IP Logged
There should be a fuse (or should have been a fuse) in series somewhere in the line before the box.
cwodavids
Member - Posts: 9
Posted: July 13, 2013 at 2:10 AM / IP Logged
As I said, power is going into the box, its the output that is not working.
Posted: July 13, 2013 at 9:07 AM / IP Logged
Can you open the box and see if there is a fuse on the circuit board?
Friday, October 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
