OEM Switches with Rostra Cruise Control?
bradleyb
Posted: December 20, 2013 at 5:35 AM / IP Logged Link to Post Post Reply Quote bradleyb
I've installed cruise control in my '01 Honda Insight. It works great with the rostra RF switch, but I have swapped to an RSX steering wheel and I want to instead use the built-in switches on the new wheel.
I got it working basically by sending the switch 12V on the common input, and hooking the two outputs to the Rostra's yellow and green wires for "Set/decel" and "Resume/accel"
The only thing that doesn't work is the "Cancel" button. The switch has no output wire for "Cancel" - instead it uses diodes to activate both outputs at the same time:
OEM Switches with Rostra Cruise Control? -- posted image.
Can anybody help me figure out how get the Rostra to understand this signal and disengage?
Thursday, April 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
