2014 Ford Fiesta Remote Start Wiring
cutter122
Member - Posts: 16
Posted: January 12, 2014 at 2:02 PM / IP Logged Link to Post Post Reply Quote cutter122
i need wiring diagram for remote start
cutter122
Member - Posts: 16
Posted: January 12, 2014 at 2:08 PM / IP Logged Link to Post Post Reply Quote cutter122
please :(
chev104275
Gold - Posts: 1,424
Posted: January 12, 2014 at 3:56 PM / IP Logged Link to Post Post Reply Quote chev104275
Check out readyremote.com they have both regular key and smart key
As always test everything before connecting
wirewise
Moderator - Posts: 489
Posted: January 12, 2014 at 4:45 PM / IP Logged Link to Post Post Reply Quote wirewise
12volts
red (15A)
ignition switch, black 7 pin plug, pin 4
Starter blue/white + ignition switch, black 7 pin plug, pin 7
Ignition BROWN / yellow + ignition switch, black 7 pin plug, pin 1
Power Lock (see factory alarm arm)
Power Unlock (see factory alarm disarm)
Lock Motor gray/brown 5 wire driver kick or BCM behind glove box, gray 16 pin plug (C), pin 3
Unlock Motor blue/green 5 wire driver kick or BCM behind glove box, gray 16 pin plug (C), pin 8
Disarm Defeat BROWN / green 5 wire driver kick or BCM behind glove box, gray 16 pin plug (C), pin 2
Parking Lights+ grn/org (LF), brn/yel (RF); pu/gn (LR), wh/og (RR) + BCM, blu 24 pin plug (D), pins 24, 12; gry 24 pin plug (G), pins 13, 1
Parking Lights- yellow/blue - headlight sw or BCM behind glove box, white 24 pin plug (F), pin 23
Hazards BROWN / yellow - hazard sw or BCM behind glove box, white 24 pin plug (F), pin 21
Turn Signal(L) blue/green (F); gray/orange (R) + BCM, blue 16 pin plug (A), pin 5; gray 16 pin plug (C), pin 12
Turn Signal(R) yellow/purple (F); GREEN/ orange (R) + BCM, blue 16 pin plug (A), pin 6; gray 16 pin plug (C), pin 13
Door Trigger GREEN/ purple - N.C. driver kick or BCM behind glove box, gray 24 pin plug (G), pin 19
Dome Supervision yellow/gray - dr A pillar or BCM behind glove box, gray 16 pin plug (C), pin 5
Trunk/Hatch Pin yellow/orange - N.C. driver kick or BCM behind glove box, gray 24 pin plug (G), pin 23
Hood Pin blue/orange - N.C. hood switch or BCM behind glove box, blue 24 pin plug (D), pin 10
Trunk/Hatch Release GREEN / WHITE (rear handle switch) - driver kick or BCM behind glove box, gray 24 pin plug (G), pin 6
Power Sliding Door N/A
Factory Alarm Arm yel/gry (key lock) and blu/brn(lock/unlock detect) - and open driver kick or BCM behind glove box, gray 24 pin plg (G), pins 10, 8
Factory Alarm Disarm pur/brn (key unlock) and blu/brn(lck/unlck detect) both - driver kick or BCM behind glove box, gray 24 pin plg (G), pins 9, 8
Disarm No Unlock (transponder and ignition)
Tachometer yellow/blue, blue/orange, GREEN/ purple, or blue ac any fuel injector, gray 2 pin plug, pin 2
Horn Trigger brown - horn switch or BCM behind glove box, green 24 pin plug (E), pin 1
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
MAKE : FORD | MODEL : FIESTA | YEAR : 2014
Smart Key:
12volts
red (20A)
RFA Module under passenger seat, white 23 pin plug, pin 1
Starter brown to BROWN / purple (SS1) - start/stop sw or RFA Module under pass seat, brn 23 pin plug, pin 22
Ignition orange / YELLOW + RFA Module under passenger seat, brown 23 pin plug, pin 18
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
MAKE : FORD | MODEL : FIESTA (SMART KEY) | YEAR : 2014
secureauto
Copper - Posts: 196
Posted: February 23, 2014 at 12:58 PM / IP Logged Link to Post Post Reply Quote secureauto
any one encounter issues with an upgrade alarm on a 2011 Ford Fiesta? I'm installing a Pursuit PROPLM. I noticed Door Lock motor wire also pulses when Unlock is pressed. Any info would be appreciated.
ASE Certified
josephpunto
Posted: August 04, 2014 at 7:04 AM / IP Logged Link to Post Post Reply Quote josephpunto
hello thanks for adding me in 12v can you pls help me on fiesta 2014 central lock what tipe it is positive or negative?? thanks josephpunto!!
catback
Silver - Posts: 703
Posted: August 04, 2014 at 10:23 AM / IP Logged Link to Post Post Reply Quote catback
Per above info locks are (-) trigger for factory arm/lock and disarm/unlock. The lock motors themselves are 5 wire.
As always test, test, then test again.
josephpunto
Posted: August 04, 2014 at 10:35 AM / IP Logged Link to Post Post Reply Quote josephpunto
thanks my friend i really appreciate your help
Posted: August 04, 2014 at 12:03 PM / IP Logged Link to Post Post Reply Quote howie ll
Except Euro Fiestas 2014 on neither have those wires in the grey plug nor the pins, you have to into the driver's door and test.
emptybee
Posted: October 22, 2014 at 5:56 AM / IP Logged Link to Post Post Reply Quote emptybee
Hi, I'm hoping someone can help me with my 2014 Fiesta ST-2 alarm. Looking for a signal wire that goes positive (negative would work too), to attach to a tracker I'm fitting, when the alarm sounds. Is there one on this model and if so could you please point me to it?
Many thanks,
Max
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
