2014 Subaru Outback 2.5i Alarm/Remote Start/Stereo Wiring
antmailster
Member - Posts: 11
Posted: August 31, 2014 at 10:51 AM / IP Logged
Anyone have wiring diagram for installing remote engine starter on 2014 Subaru Outback. Is it the same as 2013/2014 of another model, since impress or forester wiring diagrams are currently available on the12volt?
Thanks.
Tim
antmailster
Member - Posts: 11
Posted: August 31, 2014 at 11:01 AM / IP Logged
Also, I would be interested in hearing what brand/model of remote engine starters people have successfully DIY installed and like in 2014 Subaru Outback 2.5i.
Tim
tonanzith
Gold - Posts: 593
Posted: August 31, 2014 at 12:57 PM / IP Logged
This is for the basic 2014 outback not the smart key or the sport edition
Item     Wire Color     Polarity     Wire Location
12 Volts     white (40A)     +     ignition switch, white 6 pin plug, pin 3
Second 12 Volts     N/A
Starter     WHITE/ black     +     ignition switch, white 6 pin plug, pin 2
Second Starter     WHITE/ green (2.5L); WHITE/ orange (3.6L)     +     ignition switch, white 6 pin plug, pin 6
Ignition     green     +     ignition switch, white 6 pin plug, pin 1
Second Ignition     N/A
Third Ignition     N/A
Accessory     blue     +     ignition switch, white 6 pin plug, pin 4
Second Accessory     yellow     +     ignition switch, white 6 pin plug, pin 5
Third Accessory     N/A
Keysense     BLACK/ white     +     BIU right of steering column, white 34 pin plug (A), pin 4
Data Bus     WHITE/ blue (immobilizer serial communication)     data     BIU right of steering column, white 34 pin plug (A), pin 31
Can Bus High     red     data     data link connector, white 16 pin plug, pin 6
Can Bus Low     blue     data     data link connector, white 16 pin plug, pin 14
Can Bus Sw     yellow (keyless entry serial communication)     data     BIU right of steering column, white 31 pin plug (D), pin 11
Power Lock     BROWN / white     -     BIU right of steering column, white 35 pin plug (C), pin 9
Power Unlock     BROWN / black     -     BIU right of steering column, white 35 pin plug (C), pin 20
Lock Motor     lt. GREEN/ YELLOW     5 wire     BIU right of steering column, white 31 pin plug (D), pin 2
Driver Unlock Motor     lt. green     5 wire     BIU right of steering column, white 31 pin plug (D), pin 4
Passenger Unlock Motor     RED / green     5 wire     BIU right of steering column, white 31 pin plug (D), pin 3
Parking Lights (-)     BLACK/ white     -     BIU right of steering column, white 35 pin plug (B), pin 17
Parking Lights (+)     BLACK/ blue     +     dash fuse box, white 20 pin plug, pin 10
Hazards     green     -     BIU right of steering column, white 31 pin plug (D), pin 18
Turn Signal (Left)     blue     +     dash fuse box, white 20 pin plug, pin 20
Turn Signal (Right)     RED / green     +     dash fuse box, white 20 pin plug, pin 3
Headlight     pink/white     -     BIU right of steering column, white 35 pin plug (B), pin 34
AutoLights     blue (interrupt to turn off autolights)     -     BIU R of strng column, wht 35 pin plug (B), pin 16
Reverse Light     BROWN / yellow     +     driver kick, white 16 pin plug, pin 7
Left Front Door Trigger     blue/white     -     BIU right of steering column, white 35 pin plug (C), pin 14
Right Front Door Trigger     blue/orange     -     BIU R of strng column, wht 35 pin plug (C), pin 13
Left Rear Door Trigger     yellow/red     -     BIU R of strng column, wht 35 pin plug (C), pin 24
Right Rear Door Trigger     WHITE/ red     -     BIU R of strng column, wht 35 pin plug (C), pin 25
Dome Supervision     brown     -     BIU right of steering column, white 35 pin plug (C), pin 4
Trunk/Hatch Pin     lt. GREEN/ black     -     BIU right of steering column, white 35 pin plug (C), pin 33
Rear Glass Pin     N/A
Hood Pin     yellow/black (with remote start only)     -     hood sw or Remote Strt Mod bhnd dash fuse box, wht 4 pin plg, pin 4
Trunk/Hatch Release     red (release sw, Legacy) (rear handle sw, Outback)     -     BIU right of steering column, white 35 pin plug (C), pin 10
Trunk Release Motor     WHITE/ black     5 wire     BIU right of steering column, white 31 pin plug (D), pin 7
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     (arms on lock with door open)
Factory Alarm Disarm     (see disarm no unlock)
Disarm No Unlock     (transponder, ignition, and keysense)
Trunk Alarm Shunt     N/A
Tachometer     RED / white to WHITE/ green     ac     cluster, wh 40P plg, pin 30 or ECM bhnd glv box, wh35P plg(B), pin15
Wait to Start     N/A
Neutral Safety     GREEN/ black (M/T)     -     ECM behind glove box, white 31 pin plug (D), pin 16
Clutch Pedal     BLACK/ blue     +     clutch switch, white 5 pin plug, pin 1
Fuel Pump     RED / black     +     passenger kick, white 11 pin plug, pin 2
Rear Defroster     PURPLE / green     - latched     BIU right of steering column, white 34 pin plug (A), pin 26
Mirror Defroster     (mirror same as rear defrost); grn/bk (wpr deicer)     - latched     BIU right of steering column, white 31 pin plug (D), pin 9
Left Front Heated Seat     lt. green (LO)     5 wire     left seat heater switch, white 6 pin plug, pin 5
Right Front Heated Seat     white (LO)     5 wire     right seat heater switch, brown 6 pin plug, pin 5
Speed Sense     GREEN/ black or green     ac     driver kick, white 22 pin plug, pin 5
Brake Wire     BROWN / white     +     BIU right of steering column, white 34 pin plug (A), pin 10
Parking Brake     gray     -     BIU right of steering column, white 35 pin plug (C), pin 32
In order to make the ready mode neutral safety feature work properly with the electric parking brake on this vehicle, you need to use the + keysense (BLACK/ white) wire and the - parking brake (gray) wire, diode isolated and tied to the BLACK/ white neutral safety wire of the remote start. It works because the parking brake goes to sleep after a minute, and when the key is removed, the keysense stays negative. Also, the electric parking brake requires the foot brake to be pushed, so there is no way to accidentally disengage the parking brake with pushing the foot brake, thus disabling ready mode.
Horn Trigger     red     -     BIU right of steering column, white 34 pin plug (A), pin 24
Wipers     RED / blue (LO); BLACK/ blue (HI); GREEN / WHITE (ign)     +     wiper switch, white 10 pin plug, pins 3, 4, 2
Left Front Window (Up/Down)     blue/red - blue/green     A     power window main switch, white 3 pin plug, pins 3 - 1
Right Front Window (Up/Down)     red - RED / blue     A     driver kick, white 28 pin plug, pins 5 - 6
Left Rear Window (Up/Down)     WHITE/ red - BLACK/ white     A     driver kick, white 28 pin plug, pins 9 - 10
Right Rear Window (Up/Down)     blue - blue/red     A     driver kick, white 28 pin plug, pins 7 - 8
Sun Roof (Open/Close)     BLACK / YELLOW - white (function with ign on only)     +     sunroof switch, white 5 pin plug, pins 1 - 4
Sun Roof (Limit/Close)     N/A
Memory Seat 1     blue/white     -     driver kick, white 14 pin plug, pin 2
Memory Seat 2     WHITE/ black     -     driver kick, white 14 pin plug, pin 9
Memory Seat 3     N/A
Radio 12V     GREEN / WHITE and blue/red     +     radio, white 20 pin plug, pins 20, 19, or white 10 pin plug, pin 4
Radio Ground     black     -     radio, white 20 pin plug, pin 10, or white 10 pin plug, pin 7
Radio Ignition     yellow/red     +     radio, white 20 pin plug, pin 3, or white 10 pin plug, pin 3
Radio Illumination     purple (parking lights); BLACK/ white (dimmer)     +,-     radio, white 20 pin plug, pins 1, 2
On models with premium audio, they are at the radio, white 10 pin plug, pin 10, and white 6 pin plug, pin 5.
Factory Amp Turn-on     pink     +     radio, white 28 pin plug, pin 3, or white 10 pin plug, pin 9
Power Antenna     yellow/black     +     radio, white 20 pin plug, pin 9, or white 6 pin plug, pin 4
On models with navigation, it is at the radio, white 10 pin plug, pin 8.
Left Front Speaker (+/-)     BROWN / white - green or black - green     +,-     radio, white 20 pin plug, pins 8 - 7, or white 10 pin plug, pins 2 - 6
On models with amplifier, the speaker wires are brown - green at the amplifier under passenger seat, white 10 pin plug, pins 10 - 4. The tweeter wires are GREEN/ YELLOW - purple at the amplifier, white 12 pin plug, pins 9 - 3.
Right Front Speaker (+/-)     RED / yellow - WHITE/ black or red - white     +,-     radio, white 20 pin plug, pins 18 - 17, or white 10 pin plug, pins 1 - 5
On models with amplifier, the speaker wires are BLACK/ red - WHITE/ red at the amplifier under passenger seat, white 10 pin plug, pins 3 - 9. The tweeter wires are yellow - lt. green at the amplifier, white 12 pin plug, pins 2 - 1.
Left Rear Speaker (+/-)     WHITE/ red - RED / black or WHITE/ blue - ORANGE / blue     +,-     radio, white 20 pin plug, pins 6 - 5, or white 6 pin plug, pins 2 - 6
On models with amplifier, the speaker wires are BLACK/ blue - WHITE/ blue at the amplifier under passenger seat, white 10 pin plug, pins 2 - 6.
Right Rear Speaker (+/-)     blue / YELLOW - RED / white or blue / YELLOW - blue/grn     +,-     radio, white 20 pin plug, pins 16 - 15, or white 6 pin plug, pins 1 - 3
On models with amplifier, the speaker wires are black - yellow at the amplifier under passenger seat, white 10 pin plug, pins 8 - 7.
Center Channel (+/-)     N/A
Subwoofer (+/-)     blue - pink (1); blue/white - green (2)     +,-     amplifier under passenger seat, white 12 pin plug, pins 5-12; 4-10
Aux. Audio Input Left (+/-)     white - (shield)     +,-     radio, wh 16P plg, pins3-11; wh 28P plg, pins28-27
Aux. Audio Input Right (+/-)     black - (shield)     +,-     radio, wh 16P plg, pins4-11; wh 28P plg, pins26-27
RSE Video (+/-)     N/A
RSE Audio Left (+/-)     N/A
RSE Audio Right (+/-)     N/A
Satellite Radio 12 Volts
Satellite Radio Ground
Satellite Radio Ignition
Satellite Radio Antenna
Satellite Audio Left (+/-)
Satellite Audio Right (+/-)
Item     Size     Depth     Location
Headunit     irregular center of dash
Left Front Speaker     6.5     3     left front door
Left Front Tweeter     1     1     left front dash
Right Front Speaker     6.5     3     right front door
Right Front Tweeter     1     1     right front dash
Left Rear Speaker     6.5     3     left rear door
Left Rear Tweeter     N/A
Right Rear Speaker     6.5     3     right rear door
Right Rear Tweeter     N/A
Center Channel     N/A
Subwoofer     8     3     rear deck (Legacy); R rear quarter panel (Outback)
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner   below or above radio
Gary Sather
Thursday, April 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
