2011 FORD FOCUS 2DR COUPE WITH 2.0L ENGINE AND STANDARD AUDIO SYSTEM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery WHITE/ RED (+) RADIO HARNESS
Accessory GRAY/ORANGE & VIOLET/ORANGE (DATA) RADIO HARNESS
THIS VEHICLE USES THE CAN DATA NETWORK FOR ACCESSORY TURN ON
Ground BLACK/ BLUE (-) RADIO HARNESS
Illumination GRAY/ORANGE & VIOLET/ORANGE (DATA) RADIO HARNESS
THIS VEHICLE USES THE CAN DATA NETWORK FOR ILLUMINATION AND DIMMER CONTROLS
Power Antenna BLACK (+) RADIO HARNESS
Amp Turn On VIOLET/RED (+) RADIO HARNESS
THIS WIRE ALONG WITH THE SUBWOOFER AMPLIFIER INPUTS ARE IN THEIR OWN HARNESS
LF Speaker (+) WHITE
LF Speaker (-) WHITE/ BROWN
RF Speaker (+) WHITE/ VIOLET
RF Speaker (-) WHITE/ ORANGE
LR Speaker (+) WHITE/ GREEN
LR Speaker (-) BROWN / YELLOW
RR Speaker (+) BROWN / WHITE
RR Speaker (-) BROWN / BLUE
Steering Cntrls YES
Speed Cntrl NO
Radio Security YES
Security
Battery BLUE/RED (+) IGNITION SWITCH HARNESS
Ignition 1 BROWN / YELLOW (+) IGNITION SWITCH HARNESS
Starter 1 BLUE/WHITE (+) IGNITION SWITCH HARNESS
All Door Trigger GRAY/VIOLET (+) IN HARNESS IN DRIVER KICKPANEL
THE INDIVIDUAL DOOR TRIGGERS REST AT (-) AND GO TO AN OPEN CIRCUIT WHEN THE DOOR IS OPENED
LF Latch GREEN/ VIOLET (OPEN) AT SMART JUNCTION BOX UNDER DRIVER SIDE DASH
RF Latch WHITE (OPEN) AT SMART JUNCTION BOX UNDER DRIVER SIDE DASH
LR Latch GREEN (OPEN) AT SMART JUNCTION BOX UNDER DRIVER SIDE DASH
RR Latch YELLOW (OPEN) AT SMART JUNCTION BOX UNDER DRIVER SIDE DASH
Trunk Trigger YELLOW /GREEN (-) IN HARNESS IN DRIVER KICKPANEL
Hood Trigger BLUE/ORANGE (-) AT SMART JUNCTION BOX UNDER DRIVER SIDE DASH
Alarm Disarm VIOLET/BROWN (-) IN HARNESS IN DRIVER KICKPANEL TO DOOR
METER THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR
Parking Lights VIOLET/WHITE (+) IN HARNESS IN DRIVER KICKPANEL
Convenience
Headlights-Lo YELLOW/BLUE (-) AT VEHICLE LIGHT SWITCH
Headlights-Hi WHITE/ ORANGE (-) AT VEHICLE HIGH BEAM SWITCH
ALSO AT SMART JUNCTION BOX UNDER DRIVER SIDE DASH
LF Pk Lt Bulb VIOLET/WHITE (+) AT FRONT LEFT PARKING LAMP
RF Pk Lt Bulb VIOLET/WHITE (+) AT FRONT RIGHT PARKING LAMP
LR Pk Lt Bulb VIOLET/WHITE (+) AT REAR LEFT PARKING LAMP
RR Pk Lt Bulb VIOLET/WHITE (+) AT REAR RIGHT PARKING LAMP
All Hazrd Lights BROWN / YELLOW (-) AT VEHICLE HAZARD SWITCH
LF Hazrd Bulb BLUE/GREEN (+) AT FRONT LEFT TURN LAMP
RF Hazrd Bulb YELLOW/VIOLET (+) AT FRONT RIGHT TURN LAMP
LR Hazrd Bulb GRAY/BROWN (+) AT REAR LEFT TURN LAMP
RR Hazrd Bulb VIOLET/ORANGE (+) AT REAR RIGHT TURN LAMP
Trnk Release BLUE (+) AT SMART JUNCTION BOX UNDER DRIVER SIDE DASH
Remote Start
Accessory 1 VIOLET/GREEN (+) IGNITION SWITCH HARNESS
Anti-Theft Type FORD PATSŪ OR SECURILOCKŪ VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLUE/GRAY (+) IGNITION SWITCH HARNESS
Tachometer YELLOW/ORANGE (AC) AT PCM MODULE IN FRONT OF BATTERY
Brake Lights VIOLET/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights GREEN/ BROWN (+) IN HARNESS IN DRIVER KICKPANEL TO REAR
Horn BLUE/WHITE (-) IN HARNESS AT STEERING COLUMN
Modules
WIRE LOCATION
Module 1 ABS- DRIVER SIDE FIRE WALL UNDER HOOD
Module 2 PCM- IN FRONT OF BATTERY UNDER HOOD
Doorlocks/Windows
Power Unlock VIOLET/BROWN (-) IN HARNESS IN DRIVER KICKPANEL
PowerLock YELLOW/GRAY (-) IN HARNESS IN DRIVER KICKPANEL
METER THESE WIRES WHILE TURNING THE KEY IN THE DRIVER DOOR
Driver Mtr Unlock GRAY/BROWN (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
Driver Mtr Lock BLUE/GREEN (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
Pas Mtr Unlock VIOLET/GRAY (REV) IN HARNESS IN DRIVER KICKPANEL
LF Window Up BLUE/GRAY (REV) AT POWER WINDOW MASTER CONTROL SWITCH
LF Window Dn YELLOW/VIOLET (REV) AT POWER WINDOW MASTER CONTROL SWITCH
RF Window Up BROWN / YELLOW (REV) AT POWER WINDOW MASTER CONTROL SWITCH
RF Window Dn GREEN/ ORANGE (REV) AT POWER WINDOW MASTER CONTROL SWITCH
LR Window Up BLUE/ORANGE (REV) AT POWER WINDOW MASTER CONTROL SWITCH
LR Window Dn YELLOW (REV) AT POWER WINDOW MASTER CONTROL SWITCH
RR Window Up GRAY/VIOLET (REV) AT POWER WINDOW MASTER CONTROL SWITCH
RR Window Dn BROWN / GREEN (REV) AT POWER WINDOW MASTER CONTROL SWITCH
~wirewise~
