95 ranger without power door locks
shiner1
Posted: February 26, 2015 at 1:08 PM / IP Logged Link to Post Post Reply Quote shiner1
Any help on installing power door locks on 95ranger but it does not have them at all
shiner1
shark mobile
Copper - Posts: 83
Posted: February 26, 2015 at 5:38 PM / IP Logged Link to Post Post Reply Quote shark mobile
You need to install door lock actuators which is relatively simple...with that said you would then require a means to open the door remotely which there is several brands of door lock kits out there or you could put a remote start in it...the process is pretty simple and most shops will do this kind of stuff for a few hundred bucks installed with equipment. (Two front doors for that price :)
Solder, tape, repeat!
Posted: February 27, 2015 at 9:17 AM / IP Logged Link to Post Post Reply Quote howie ll
Buy a complete kit from SPAL including an internal switch (optional).
It will have the special (timer) relay wiring and wiring instructions.
They also do them as a keyless entry (remote control) option.
Posted: February 27, 2015 at 9:31 AM / IP Logged Link to Post Post Reply Quote howie ll
This from Amazon, note, I haven't a clue as to its quality:-
http://www.amazon.com/Universal-Central-Unlock-Conversion-actuators/dp/B0033YECEK/ref=pd_sbs_auto_1?ie=UTF8&refRID=15NKPVMPTGBCVNHHSN2Q
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
