5704 Python dball2, 2003 Camry
w.w.rabon
Member - Posts: 17
Posted: March 25, 2015 at 10:09 PM / IP Logged Link to Post Post Reply Quote w.w.rabon
I hooked up the door trigger thank you doctor. Now it doesn't chirp 1x or 2x I believe after holding it for about 4 seconds it chirps 3 times I could be wrong but it chirps more than once. I've tried doing several times holding down longer like 30 seconds and still only one response after about 4 seconds it chirps a few times I try to go thought switching it to automatic but no avail. also the trunk pop does that require a relay if so how do I wire it I've looked into it and have gotten two different explanations.
William W Rabon
tedmond
Gold - Posts: 4,610
Posted: March 26, 2015 at 10:45 PM / IP Logged Link to Post Post Reply Quote tedmond
to program, it needs to see door triggers and ignition. verify your ignition input as well. read the programming instructions over, as they are not so easy for the diyer
you definitely need a relay
85 - trunk release of python
86/87constant 12v fused
cut trunk release wire in half
87a - trunk wire towards plug
300 - trunk wire away from plug
Ted
Compustar Expert
Posted: March 27, 2015 at 2:51 AM / IP Logged Link to Post Post Reply Quote howie ll
Green H2 door trigger wire, verify it goes to ground when a door is opened.
Pink H3 heavy duty loom, make sure it goes live, AKA hot or 12 volts + on ignition.
Press and hold programming button with ignition on and door open.
Siren will chirp once after about 5 seconds for Menu 1, keep pressed to access further menus.
You need level 3, release button, press, release and hold, 1 chirp then press "arm" button on remote to change to auto.
Page of 4
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
