95 Jeep ZJ arrow2 alarm
bigbadbrother
Posted: March 27, 2015 at 9:59 PM / IP Logged Link to Post Post Reply Quote bigbadbrother
95 Jeep Grand Cherokee
Clifford Arrow 2 Alarm
I’ve installed a Clifford arrow 2 alarm in to my 95 ZJ and I can’t get the starter interrupt relay to work. My big question is the second wire (red #1) coming off of 85 on the relay. where does that run to? I’ve run it to 12v power and the alarm stops working and I even tried using the second wire off of 86 with the same results. I know I can get a new alarm but I can’t afford one right now and this is what I have. P.S. the factory alarm is dying fast.
Thank You
95 Jeep ZJ arrow2 alarm - Last Post -- posted image.
Posted: March 28, 2015 at 5:51 AM / IP Logged Link to Post Post Reply Quote howie ll
Posted: March 28, 2015 at 5:54 AM / IP Logged Link to Post Post Reply Quote howie ll
Actually bad diagram should wire as follows, is there a diode across 85 and 86?
If not green to 85 1 wire from ignition to 86
Key side starter to 87a and starter side to 30
If there's a diode observe where the band is, ignition should always go to the band side.
Posted: March 28, 2015 at 9:25 AM / IP Logged Link to Post Post Reply Quote howie ll
Looking at that diagram again the red wire goes to ignition.
Green is the alarm's Ground While armed (GWA) and goes to ground when the alarm is armed, then if any one tries to hot wire, circuit is made, and opens connection between 87a and 30 thus disabling your starter circuit.
Test:-
Green goes to ground.
Terminal 86 shows 12V+ on ignition and crank.
Ignition on, ground 86, you should hear the relay click.
bigbadbrother
Posted: March 28, 2015 at 3:45 PM / IP Logged Link to Post Post Reply Quote bigbadbrother
Thank you for the reply's. I think the reason I couldn't make it work is the alarm isn't pushing enough current to trigger a relay. I'll pick up a new one soon when I can find it at a good price.
Thank You
Posted: March 28, 2015 at 6:57 PM / IP Logged Link to Post Post Reply Quote howie ll
Arrow 2 has been discontinued for about 20 years!
Posted: March 28, 2015 at 6:59 PM / IP Logged Link to Post Post Reply Quote howie ll
Arrow 2 has been discontinued for about 10 years, the 3 came out in 07, now we have the Arrow 5.
Wednesday, April 24, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
