2015 Chrysler 200, satellite radio through factory radio
pts760
Copper - Posts: 403
Posted: April 10, 2015 at 11:16 AM / IP Logged Link to Post Post Reply Quote pts760
Not sure if this is posted in the right area but I have a 2015 Chrysler 200 and would like to connect satellite radio through my factory radio like the factory(no portable unit). I have Uconnect v5.0 with a 5" screen. Does anyone know of a company that can make my wishes come true.
I drink current, eat ohms, and bleed voltage
dairyboy3
Copper - Posts: 52
Posted: April 10, 2015 at 8:05 PM / IP Logged Link to Post Post Reply Quote dairyboy3
Chrysler radios usually have the satellite tuners built into the actual radio itself. That's how it was on those cars in previous years. the satellite antenna actually plugged into the radio itself since the tuner was internal. Not sure on your car but I just worked on a 2015 Jeep and 2014 Charger and both had internal sat tuners in the radio.
pts760
Copper - Posts: 403
Posted: April 11, 2015 at 3:38 PM / IP Logged Link to Post Post Reply Quote pts760
It's the radio has an internal tuner do I just plug and the antenna in and activate the satellite radio. If so do you usually use a factory antenna from the dealer or is there an antenna that you can get that will plug into the back of the radio that's aftermarket
DYohn
Moderator - Posts: 10,741
Posted: April 12, 2015 at 9:30 AM / IP Logged Link to Post Post Reply Quote DYohn
Check out a PAC IS32
dairyboy3
Copper - Posts: 52
Posted: April 14, 2015 at 1:22 PM / IP Logged Link to Post Post Reply Quote dairyboy3
If it already has the tuner internally it should have the antenna. Might have to pull the radio and find out. If it does You might have to get the radio reprogrammed at the dealer to make the satellite feature available. I added a factory backup cam to a 2014 Charger but he still had to take it to the dealer to reprogram the radio in order for it to work since I do not have the tool to do so.
Thursday, March 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
