Delay driving lights off.
jabartram
Member - Posts: 6
Posted: April 17, 2015 at 9:33 PM / IP Logged Link to Post Post Reply Quote jabartram
I have HID conversions in my ram, im adding high beam hids i already hve driving light hid, i want my driving lights to work with my high beams, we travel on ranch roads at night and its freakin dark. my truck shuts off the driving lights when switched to high beams. i have the relat system set up to run the high beams and driving lights but i dont want the driving lights to shut off for a split second while switching between high and low beam, so i want to add in a 528t pulse timer to hold the driving lights on for a few seconds but i cant figure out how to connect the wires on the 528t?
enoxos
Member - Posts: 34
Posted: May 10, 2015 at 10:15 PM / IP Logged Link to Post Post Reply Quote enoxos
search for latching relays on this site.
Ween
Platinum - Posts: 1,366
Posted: May 10, 2015 at 11:01 PM / IP Logged Link to Post Post Reply Quote Ween
Hi,
Does the driving light conversion have its own relay to power the ballasts? If so, a diode (1N400* series) and electrolytic capacitor connected on that relay's coil is all that is needed. The diode (in series) isolates the relay coil, the capacitor (in parallel with the coil) adds the delay.
jabartram
Member - Posts: 6
Posted: May 10, 2015 at 11:04 PM / IP Logged Link to Post Post Reply Quote jabartram
Ween wrote:
Hi,
M
is there a diagram i can look at to do this?
Ween
Posted: May 11, 2015 at 10:28 PM / IP Logged Link to Post Post Reply Quote Ween
https://www.the12volt.com/relays/relaydiagram22.html
The +12 volts from turn signal is the driving light wire from the vehicle, ground is ground, fused +12 volts is power from the battery, 12 volt output to turning lamps is +12 volt power to the hid driving light ballasts. Altering the capacitor's value will increase or decrease the delay.
Wednesday, April 24, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
