94 integra clifford 5706 remote start harness
jpbook
Posted: April 26, 2015 at 10:51 PM / IP Logged Link to Post Post Reply Quote jpbook
Hi I'm installing a clifford 5706x on a 94 integra and I'm a little confused with the Remote start, 10pin heavy gauge harness
1. NC
2. (+) Fused 12v Accessory/Starter input
3. (+) Flex Relay input 87A key side (if req)
4. (+) Ignition 2/Flex relay output
5. (+) Fused 12V ignition 1 input
6. (+) Starter input (key side)
7. (+) starter output (car side)
8. (+) Accessory output
9. (+) Fused 12v Ignition 2/Flex relay input 87
10.(+) Ignition 1 Input/Output
On the car the Ign harness has
Constant 12V+     White   Ignition Switch Harness
Starter BLACK/ White       Ignition Switch Harness
Ignition     BLACK / YELLOW       Ignition Switch Harness
Accessory     Yellow   Ignition Switch Harness
What wires from the alarm harness do I not need?
how do I wire those 4 from the cars ign harness to the alarms remote start harness? Any help would be greatly appreciated thank you
Posted: April 27, 2015 at 5:28 AM / IP Logged Link to Post Post Reply Quote howie ll
2, 5 and 9 to the white.
Cut BLACK/ white, 6 to key side and 7 to starter motor side.
8 to yellow.
10 to BLACK / YELLOW.
Are you sure there's only one ACC?
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
