how to wire in over ride for electric fan
83trekker
Member - Posts: 27
Posted: May 18, 2015 at 12:26 AM / IP Logged Link to Post Post Reply Quote 83trekker
I have a aftermarket electric fan kit for my early 80's chev 350. It has on the relay 1 wire for battery constant run through a breaker, 1 wire to the electric fan +, 1 wire to acc + when key is one, 1 wire to a thermostat in the head for the ground which is also the thermostat for the relay when engine hits 185f. Its a 40/60 amp relay.
The electric fan is grounded to the body.
I am wondering how to wire in so I can turn the electric fan on anytime I want to help cool it, kind of like a newer vehicle when you turn the ac on it auto kicks on the fan on.
Im stumped any help would be great, thanks!
Posted: May 18, 2015 at 2:12 AM / IP Logged Link to Post Post Reply Quote howie ll
Join a wire to the thermostat wire, run it to a switch and ground the other side.
If you want illumination, 12V+ ACC to lamp, other side to joined wire.
hotwaterwizard
Silver - Posts: 1,350
Posted: May 18, 2015 at 8:55 PM / IP Logged Link to Post Post Reply Quote hotwaterwizard
Yea just put a switch across the Thermostat.
_
/_ 0
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
83trekker
Member - Posts: 27
Posted: May 19, 2015 at 8:31 AM / IP Logged Link to Post Post Reply Quote 83trekker
worked perfect thanks all!
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
