2013 hyundai elantra gt heated seat
tianot
Copper - Posts: 155
Posted: July 21, 2015 at 12:09 AM / IP Logged Link to Post Post Reply Quote tianot
hello guys! i installed a remote starter into a 2013 hyundai elantra gt using a compustar cm7200 module. how can i connect the heated seat into the compustar cm7200 module? what wire should i use from the cm7200 to activate the heated seat?
thanks
tianot
yellow_cake
Copper - Posts: 178
Posted: July 29, 2015 at 10:49 AM / IP Logged Link to Post Post Reply Quote yellow_cake
I haven't seen the wiring diagram for this vehicle to see if the power wires can be tapped without issues...
Correct me if I'm wrong, judging by photos online, the heated seat switch is a momentary press button built into the center console.
You could try this method if your experienced and comfortable with soldering/working on a circuit board. https://www.the12volt.com/installbay/forum_postsm.asp?tid=138044
Posted: July 29, 2015 at 12:03 PM / IP Logged Link to Post Post Reply Quote howie ll
Absolutely superb attention to detail, you've gone where no one has before except maybe Kreg, Ted and myself2013 hyundai elantra gt heated seat - Last Post -- posted image.
bs1d3
Copper - Posts: 58
Posted: August 02, 2015 at 4:28 PM / IP Logged Link to Post Post Reply Quote bs1d3
I'm seeing them as being positive triggers in the kick panels, use the defrost POC and a relay to convert to a postive output and test to see if they are pulsed or latched.
Driver seat is GREEN/ orange, driver kick, white 43 pin plug, pin 9
Pass seat is BROWN / orange, passenger kick, white 56 pin plug, pin 9
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
