2013 Chrysler Town and Country, Python 5706
507 w
Member - Posts: 19
Posted: August 21, 2015 at 2:45 PM / IP Logged Link to Post Post Reply Quote 507 w
Hello, I want to install a python 5706 on my Chrysler town and country 2013. What bypass module do I need? And where do I get that information? Thank you
The Broken Link
Platinum - Posts: 7,783
Posted: August 22, 2015 at 8:34 PM / IP Logged Link to Post Post Reply Quote kreg357
I can recommend either the ADS AL-CA from iDatalink or the EVO-ALL from Fortin.  I have used both with excellent results.
Here is a link for the iDatalink info :  http://www.idatalink.com/support
Here is a link for the Fortin info :  http://fortin.ca/en/
You didn't mention if the van had Push To Start or plastic key.  If you are planning to connect the bypass module to the Python with the D2D harness, you will need to get a special version of firmware flashed onto the iDatalink or Fortin module that requires the use of their flash USB cable.
My current work van is a 2013 Dodge Caravan without PTS.  Running an Avital 4113 with an EVO-ALL in W2W mode.  Here is a link to the Pictorial :  https://www.the12volt.com/installbay/forum_posts.asp?tid=134484
507 w
Member - Posts: 19
Posted: August 28, 2015 at 7:00 AM / IP Logged Link to Post Post Reply Quote 507 w
The Broken Link
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
