Garage door opener
racerjames76
Silver - Posts: 581
Posted: August 26, 2015 at 9:38 AM / IP Logged Link to Post Post Reply Quote racerjames76
I was reading on Directed's forums today about a guy who used an extra alarm module to control his shops garage door opener. Our shop has a very old opener that does not have a remote control capable brain.
I am wondering how hard it would be to use an older keyless entry system say even a modern Auto Mate 4104a and have it setup that pressing unlock would open the garage door and pressing lock would close the door.
The switch on the wall is a 3 button OPEN/STOP/CLOSE momentary switch setup. Using 24v and simple momentary contact to operate the functions.
I would have a 12v battery maintainer plugged in and mounted near the opener switch, which would provide 12v power (and ground) to the 4104. I would only be using the 4104 to operate relays to make the contact for the opener switches.
My first question is will a standard 5 pin 30/40a 12v relay be able to handle the 24v momentary voltage of the opener switch, and if not would a 24v specific relay be able to be controlled by a 12v keyless entry system?
To master and control electricity is perfection. *evil laugh*
Posted: August 28, 2015 at 9:17 AM / IP Logged Link to Post Post Reply Quote howie ll
Within reason the voltage on the switch side doesn't matter, only the coil. Most 12V automotive relays work in the range 7.5 to 18 volts in practise.
Thus as long as the 30/40 (you can also get 40/40) will handle the motor current you're OK, 30 amps at 12 volts = about 18-20 amps at 24 volts.
In Europe most trucks over 3 tons use 24 volt electrical systems with droppers for the radio so yes I've used this trick many times with a 12Volt alarm.
racerjames76
Silver - Posts: 581
Posted: August 28, 2015 at 11:39 AM / IP Logged Link to Post Post Reply Quote racerjames76
Well since the buttons i plan to operate are momentary meaning press and release and the door continues until fully open/closed i dont think the relay would see anything other than a brief 24v signal across 30 and 87 when activated. If thats true then the 30/40 relay should be fine.
Posted: August 28, 2015 at 12:12 PM / IP Logged Link to Post Post Reply Quote howie ll
Yes, no problem there what about the door's current draw.
the12volt
Administrator - Posts: 3,955
Posted: August 28, 2015 at 1:05 PM / IP Logged Link to Post Post Reply Quote the12volt
Howie, from racerjames76's description, the door motor's current draw is not through the 3 button wall switch and will not be through the relays he intends to add.
Garage door opener - Last Post -- posted image. the12volt • Support the12volt.com
Posted: August 28, 2015 at 1:07 PM / IP Logged Link to Post Post Reply Quote howie ll
Point taken! Thanks. It's my age, cogitative disassociation!
chev104275
Gold - Posts: 1,424
Posted: August 29, 2015 at 7:41 PM / IP Logged Link to Post Post Reply Quote chev104275
I've done what you describing quite a few times. Works great.
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
