2014 toyota camry le auto lights
mandeepsaini66
Posted: August 30, 2015 at 10:15 PM / IP Logged Link to Post Post Reply Quote mandeepsaini66
Hey guys, I installed a remote start in 2014 Toyota camry, everything works fine except auto light setting is on and lights stays on after vehicle is shut off from remote start. I am aware that a relay is required but please advise on how to wire it.
thanks in advance
Posted: August 31, 2015 at 4:32 AM / IP Logged Link to Post Post Reply Quote howie ll
Green NEG (-) Body ECU on dash fuse box, wht 30 pin plug, pin 28.
Use a wire linked to either disarm or diode separate the two and use an aux linked to R/S shutdown.
smokeman1
Platinum - Posts: 1,588
Posted: August 31, 2015 at 6:26 AM / IP Logged Link to Post Post Reply Quote smokeman1
Which bypass are you using?
mandeepsaini66
Posted: August 31, 2015 at 9:08 AM / IP Logged Link to Post Post Reply Quote mandeepsaini66
I used compustar cm7200 brain with blade al bypass
Thursday, April 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
