2005 F150, installing Avital 5303L and PKFM
davep.
Gold - Posts: 641
Posted: October 06, 2015 at 5:19 PM / IP Logged Link to Post Post Reply Quote davep.
I should have read it again before posting. I have a good memory, but I guess not "terrific". The tip is for Normally CLOSED door triggers. Fords are normally open. I still think the strategy I outlined above would work. But there must be a solution for this out there somewhere.
The tip I was referencing is tech tip 1921 10-09
EDIT:  Here's a couple more thoughts.
You say the remote indicates "door open" is causing the alarm. Look at the LED when it triggers. Door trigger is 3 flashes. If it isn't 3 flashes, it's another trigger. Be sure you're chasing the correct gremlin.
 Why did you use the door switches? Most of my experience is with GM, but I've done a couple of Fords, and I used the blk/blu wire at the dome lights. Program the Avatal for "no door open chirps" so you don't get warnings from the delayed dome lights. You also use the (+) door trigger input on the Avatal. Worked fine for me, and a lot less work than intercepting all the door inputs to the BCM.
There's some more ideas.
s20dbond
Member - Posts: 8
Posted: October 07, 2015 at 2:46 PM / IP Logged Link to Post Post Reply Quote s20dbond
I don't know how to attach files here, but I added diodes to the door trigger wires with non striped ends torward the bcm, according to the tech tip I listed earlier, 1076. It works exactly as it is supposed to now. Thanks for your help Davep. I wouldn't have had any idea where to look without your help. I also discussed it with and Electrical Engineer friend of mine, and he helped me quite a bit too. He explained why I needed to add the diodes in the way that I did.
Thanks,
Doug
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
